Defender Talk about the Land Rover Defender within.
Towing with a defender
Old Aug 21, 2007 | 01:17 PM
rbarna's Avatar
4th Gear
Default Towing with a defender
Is it a bad idea to tow an enclosed race car trailer with a '95 defender? The trailer weights 3400lbs and the car weights 1600lbs. Will it have enough power to go up hills? Will 4wd be an issue? Will wind be a problem?
Thanks!
-Ross
Old Aug 22, 2007 | 04:21 AM
Adz's Avatar
Adz
Default RE: Towing with a defender
Defenders are permanent 4WD and are just fine on tarmac. They make fabulous towing vehicles - the 5,000lB combined weight of your race car and trailer isn't even close to the maximum towing weight for the vehicle (3,500kgs or 7,700lBs) Depending on the hills you might have to drop a cog or two but motorways here in the UK are generally no problem for my Tdi which has a bit less power, but about the same torque, as a NAS V8.
Cheers,
Blakesrover
Feb 20, 2013 10:31 PM
RobFrey1
Oct 14, 2005 12:14 PM
Benhamtroll
Jul 22, 2005 12:31 AM
sixpack
Jul 5, 2005 04:41 AM
listed
Jun 12, 2005 06:57 AM
