Detailing Discuss detailing your ride within.
"claying"
Old Apr 11, 2007 | 08:15 PM
rphotographer's Avatar
Default "claying"
Hello all,
has anyone used "claying" on your finish? the detail men say its really makes a nice finish.
just need some feed back.
Thanks
Ralph
Old Apr 11, 2007 | 09:51 PM
fire1427's Avatar
Default RE: "claying"
yes claying removes embedded debris done right it's great ... done wrong leaves streaks and swirls/whirls
Old May 28, 2007 | 07:26 PM
drewbiedoo's Avatar
6th Gear
photographer-
I have used a claybar about 3 times on my disco II. It works magic - i was simply amazed the first time i used the claybar on it. The amount of gunk that came up out of the clearcoat was unbelievable.
The best part about it is, after you use theclaybar, a coat of wax goes on easier, comes off easier, and lasts much longer. From what I was told from the folks at Meguiars, the claybar allows the wax to bond better to the surface of the car, lasting longer.
I didn't think there was much technique to putting it on. Just spray the lubricant, and work the clay in circles until you can't feel the "gunk" anymore. It's labor intensive, but in my opinion, well worth the time and effort.
Old May 28, 2007 | 09:00 PM
fire1427's Avatar
http://autopia.org/forum/guide-detai...-cleaning.html
Old Jul 10, 2007 | 05:56 PM
the shine shop's Avatar
in my opinion,if you do not clay before you polish and finish,you are wasting your time.
check out meguiarsonline.com and you will get all the info you need
mike
Old Jul 30, 2007 | 12:56 PM
SpeedAgent's Avatar
Do it, but do it right. Once you see the results you will be convinced to use a clay bar forever as part of your detailing regimen.
Old Aug 1, 2007 | 06:21 PM
ferdierooke's Avatar
Definitely I agree with 'the shine shop' based on my own experience..
Old Aug 9, 2007 | 07:58 AM
jwfuller's Avatar
I tried it, and it was pretty amazing. I could not believe the amount of gunk it was pulling out of the paint. Definitely something to do before you do a polishing job or something abrasive.
Old Dec 16, 2007 | 05:22 PM
tailchaser0527's Avatar
Be sure to keep the surface wet, I use meguiars quick detailer.
Old Jan 10, 2008 | 10:52 AM
Roverboy3766's Avatar
can you get the clay and the supplies and advanced auto parts?
