Alternator suggestion
Actually both. I have (4) Hella lights on my Hannibal rack and (2) LR safari lights that I use when off roading. My volts drop from 13.5 to about 11.5 as soon as I turn them on. My fear was the additional amperage and the thin wiring on these disco's would be an issue. But after reading, perhaps not.
Look the parts store chains are there to sell you parts, any parts at attractive pricing and convince you for example that an 02 code (because they scan for free ) the hand held says so!--In turn they sell you four sensors as well--only to discover that it doesn't fix the job because other non scan-able engine faults are present .
The lifetime warranty mantra bit fits very well into a marketing projection because in most cases the car the DIY'r has bought and installed has been sold to a third party so they get to sell that part again and again and again over the lifetime of the vehicle.
I suppose my pet peeve is the can of refrigerant on the shelf ready to strike devastation to an unsuspecting "walk in" customer with an A/C problem. No certification of purity, often a cocktail mix of undisclosed refrigerant products (remember R40 is very corrosive to alum parts) the oils suspended in the mix and sealant which all reduce the life of a compressor by about 50%. Then they get to sell you a new one!
Not to mention that the DIY'r is often venting the junk into the atmosphere. Something which professionals in the industry are forbidden to do!
With the average life of a vehicle in the US now being 11 years old the potential DIY fix it business is big business.
T/V
All right, I will be installing my 5th Autozone alternator tomorrow in less than 6 months. Seems the bearings they are using aren't sufficient for the task at hand. I am now looking for a supplier who sells rebuilt Land Rover genuine alternators as I used mine as a core.
I've been through a few Alt's on the Disco too. Can change it in ten minutes now LOL. I ended up going to a local family run alt/starter repair shop for mainly industrial equipment. I took them three broken OEM Alt's. For $100 he pieced together two good alt's from the three (plus a few spare parts he had laying around), so I have one on the truck and one spare. Have been running this Alt for ~2 years now. May do an upgrade as mentioned in this thread if this one fails.
If I understand correctly the RRC alternator is also 120 amps and if rebuilt should work just as well?
I'm looking for something with a little more juice for an aftermarket stereo system, and any future lights I want to add. Potentially winching as well.
Can't speak to that particular one.
I upgraded to a 120 and bought it from BP Utah last year. It's a Magneti Marelli and was a pretty penny. I don't see it on their site anymore but this was the old link....
Land Rover Discovery Series I OEM Magneti Morelli Denso Alternator
