Best tire pressure for 235/85/16
I have a new set of Goodyear Duratracs size 235/85/16. I was wondering if anyone has experimented with different tire pressures to see what works the best. Or should I just use the recommended 26 front 36 rear?
Vehicle is a 95 Discovery with little to no load and mostly road use with a 2 inch lift.
Duratrac Tires based on your model are rated 'E', which means that the maximum each tire will do is 3,042 lbs @ 80 PSI. This is the most you can inflate the tire before it explodes from too much air pressure.
Following Land Rover Discovery's difference in tire pressure (it was engineered that way for a reason) the long and short should be around the following numbers below, provided your tire is the 'E' rating (Meaning the 10 PLY SUPER DUPER TOUGH TIRES)
Goodyear Duratracs size 235/85/16 inflation for Land Rover Discovery 1
Front Tires: 36 PSI
Rear Tires: 50 PSI
I have the BFG All-Terrain T/A KO and has a similar rating to yours, just my size is slightly different (245/75/16). I played with the PSI and found that I found it comfortable for me at Front 32 PSI Rear 44 PSI, mind you I need to replace my bushings.
The madness... I mean... Math is below
- 4,400 lbs (Total Curb Weight Stock)
Front Axle Curb Weight is roughly 40% of the total Curb Weight of the Discovery.
Front Axle Curb Weight : 4,400 lbs x 0.40 = 1,760 lbs
Rear Axle Curb Weight is roughly 60% of the Total Curb Weight of the Discovery.
Rear Axle Curb Weight : 4,400 lbs x 0.60 = 2,640 lbs
Lets' test that shall we to make sure the math adds up thus far
Front 1,760 lbs + Rear 2,640 lbs = 4,400 lbs (Correct!)
The OEM tires were Michelin LTX MS if I am not mistaken, and they had a load rating per tire of...
2,365 lbs @ 44 PSI
Therefore lets do some more math...
Original Front Axle Curb weight was 1,760 lbs divided by two (each axle has two wheels) which leaves us with 880 lbs per tire as the load weight we have to account for in the front.
Lets do more math again
Original Michelin LTX MS tire ratings:
2,365 lbs divided by 44 PSI gives us 53.75 lbs/PSI
Therefore, Land Rover states that the stock front tires require 26 PSI for best fuel economy and safety (has to do with steering, that's why the front tires have less air in them than the rear tires).
That means 26 PSI x 53.75 lbs /PSI and each tire would be able to support 1,397.5 lbs at that pressure.
Lets go back to the new Duratrac Tires:
3,042 lbs @ 80 PSI
3,042 lbs divided by 80 PSI = 38.025 lbs / PSI
so we know that we would like to be similar to the weight distribution of the original OEM inflation ratio/weight at 1,397.5 lbs for each front tire.
Final Formula for new Front Duratrac tires based on your size and spec:
1,397.5 lbs divided by 38.025 lbs/PSI = 37 PSI (Rounded from 36.75 PSI)
Rear axle 2,640 lbs divided by 2 (two tires) = 1,320 lbs per tire
Original rear tires needed 36 PSI per tire as per manufacturer for best fuel economy and safety.
Original Michelin LTX MS Tire Manufacturer rating:
Rear OEM tires required 36 PSI
So 36 PSI multiplied by 53.75 lbs / PSI = 1,935 lbs
Go back to new tires... 3,042 lbs @ 80 PSI
so we know that we need 1,935 lbs for each rear tire therefore...
Final Formula for new Rear Duratrac tires based on your size and spec:
1,935 lbs divided by 38.025 lbs/PSI = 50 PSI (Rounded from 50.88 PSI)
ebg18t
04-23-2012 10:13 PM
s4lex
08-11-2008 04:58 PM
s4lex
05-02-2007 10:10 PM
