What spark plugs are best for a 98 Disco V8?
Old Dec 29, 2008 | 11:40 AM
VikingDiesel's Avatar
Default What spark plugs are best for a 98 Disco V8?
I call the dealer and they say that out cars use CHAMPION from the factory but are $12 a piece which is out of control, so what else works just the same? Also, does it have to be some special spark plug wires or can I just pick some up from Napa?
Old Dec 29, 2008 | 12:48 PM
hazletbassist89's Avatar
Default RE: What spark plugs are best for a 98 Disco V8?
Magnecore 8mms for the wires and Bosch Platinum +4 plugs. That's what DiscoMike recommends so it's good enough for me
Old Dec 29, 2008 | 12:50 PM
mattrickman's Avatar
You'll want to run magnecor 8mm wires. You probably won't find those at Napa.
As far as plugs, I use Bosch Platinum +4's
Old Dec 29, 2008 | 01:18 PM
So the BOSCH 4 prongs are the best for our cars, where do I get those wires from? Any comparable stuff from NAPA, AUTOZONE or ADVANCED AUTO for the wires? These are the plugs I should use for my car?
Old Dec 29, 2008 | 01:40 PM
Call Tony at 650-365-4145, he owns a Rover shop the LRRF and a retail outlet for Rovers, for one of the better prices on line
Old Dec 29, 2008 | 03:17 PM
for the wires? But those are the spark plugs, right? How about the BOSCH IRIDIUMs, or should I just stick with the +4's?
Old Dec 29, 2008 | 05:45 PM
Yes you can buy those plugs anywhere.
Iridium or otherwise.
You can buy the Champions at the autoparts store for about $2 each, the dealer has a huge mark up.
Old Dec 29, 2008 | 07:13 PM
llesra's Avatar
ngk v-power (copper) or g-power (platinum) plugs with 8mm kingsborne wires
http://www.kingsbornewires.com/produ...;productId=756
Old Dec 29, 2008 | 07:25 PM
How long have you been using those Kingsborne wires?
Old Dec 29, 2008 | 07:34 PM
are the CHAMPION single prong?
