discovery 300tdi auto 1994 heater/temp problem??
Old May 12, 2012 | 04:39 PM
Benjamin Wright's Avatar
4th Gear
Default discovery 300tdi auto 1994 heater/temp problem??
i have a 1994 discovery 300 tdi auto, yeaterday i had to replace the waterpump due the bearing going, so replace with a geniune one, today after getting up to temperature, put the heating on and was blowing cold air, then after driving a bit further the temperature guage went right to the top for about a minute, so went to pull over then all of a sudden the temp went back down to half way, and the heater was blowing hot air, its done this twice today! can anyone shed some light on this please?????
Old May 12, 2012 | 05:09 PM
You have air in the system, you need to bleed all of the air out.
Fill the coolant resevoir, turn the heater on full hot, with the coolant cap off start the engine and run it up to temp.
Once full operating temp is reached and you have hot air coming out of the heater put the coolant cap back, shut off the engine and you are good to go.
Check the coolant level a few days after driving to make sure it is still full.
Old May 13, 2012 | 03:30 AM
4th Gear
thankyou for the advice will do that this morning
Old May 13, 2012 | 03:43 PM
4th Gear
have bled the cooling system and alls good thanks
Old May 13, 2012 | 04:40 PM
Thank you for reporting back.
Glad to hear it all worked out for you.
flashman.tv
Aug 18, 2013 09:19 AM
Mart 678
Dec 3, 2012 01:56 PM
The Devil Made Me Do It
Jun 16, 2011 01:38 PM
rrbc
Nov 13, 2009 04:59 PM
FarmGirlie
Sep 28, 2009 12:49 PM
