Y-Pipe recommendations
You've reported the failure already, working on the issues as we speak......
I know, it's tough sitting on a wad of $100 dollar bills but that's why they invented the Ball Mason jar and kitchen cabinets with doors. For the five miles you drive you could've snagged a Hovaround with a handlebar basket or a brand new recumbent with a Lazyboy zip tied to it.
I can see you have inter-web but how long have you been on that island?
I did see them priced at the same as AB's now that the AB's are no longer on sale but I also see the pictures showing the cats to be the same size where the AB's are 2 different sizes.
don't want to throw a wrench, but .. just in case
I have lived on the Island for 13+ years.
I hope that works for you, The shop I mentioned used the magnaflows as an example of ones that caused the sensor errors. (one incident) I hope they were wrong.
I also bought new sensors so maybe that will all work out fine!
I couldn't help myself, glad you got it. For what it's worth I hope it does work out. I know of several that have not including those made up from muffler shops just recently. I have a welder, I'm out of the entire exhaust worry loop.
Mission Accomplished!
The weather and my schedule finally aligned and I managed to get the y-pipe and cat back system replaced today. Took me most of the day but it is DONE!
I used the Magnaflow y-pipe + cats and the stainless steel Magnaflow cat back without a resonator (chrome exhaust tip). It was a direct fit and I only had to cinch up the manifold -> y-pipe connections after firing it up and discovering it was leaking just a bit.
On removing the factory parts, I was fortunate that none of the studs snapped. I'm guessing my liberal use of PB Blaster may have helped!
I did have to saw off the resonator in order to get the factory muffler/resonator out.
I also replaced the rubber mounts and the nuts to the manifold.
Although I had ordered an "olive" metal gasket that is supposed to go between the y-pipe and muffler connection, I didn't need it. There wasn't one in the factory setup and it wouldn't have fit anyway. Inexpensive part, so no harm.
Also replaced the O2 sensors behind the cats since I was there. I replaced the other 2 last year.
The Disco sounds great (like a 4x4 muscle car) now and so far no codes!
Removal of cat back end of the system isn't hindered by anything other than needing to hack off the resonator. I suppose one might be able to lift the rear end and allow the axle to articulate enough to thread it through. My resonator was toast (rusted thru) so I didn't care about sawing it off.
Now to find a scrap metal yard to unload the old stuff on.
Update: Leaks!
After driving around for a bit and parking the truck overnight I discovered there were leaks at each of the clamp points (not surprising I guess) and one pinhole in a weld joint in the driver side cat.
Bought and applied some Permatex 80335 to the joints and the pin hole, re-clamped to the recommended torque setting and let it dry for an hour. Fired up the engine and let it run for 10 min per instructions and took it for a drive. Leaks appear to be sorted.
Hopefully that will hold, else I will be visiting a muffler shop to have the clamp points welded up.
