range rover wheels on disco
Old Oct 4, 2007 | 04:07 PM
brandodisco's Avatar
Default range rover wheels on disco
hello i found a deal on a set of range rover wheels and i was wondering if they would fit my 00disovery? im not sure the year they came off of, but the seller believes the part number is 6-751-305, 8J x19 eh2
[IMG]local://upfiles/7884/408B43CD0D574D289F8D8E087B5F55A3.jpg[/IMG]
[IMG]local://upfiles/7884/B4509D3F9CF04E38993F1717689F1103.jpg[/IMG]
Old Oct 4, 2007 | 04:08 PM
Default RE: range rover wheels on disco
also any clue on how wide they would be? thanks brandon
Old Oct 4, 2007 | 04:26 PM
okdiscoguy's Avatar
I know the 8J X 19 is 8" wide and 17" tall. Find out what year of RR, but I really think the D2 and RR share the same rims. We are limited on D1's, but pretty sure RR wheels will fit a D2. Wait for DiscoMike to chime in.
Old Oct 4, 2007 | 04:53 PM
llesra's Avatar
the wheel is 19"x8". to fit them, youll need new lug nuts off a 2003+ range rover and hubcentric rings.
Old Oct 4, 2007 | 06:24 PM
what is a hubcentric ring? is that like a spacer?
Old Oct 4, 2007 | 07:26 PM
llesra's Avatar
its a small ring that goes over the hub to center the new wheels due to the larger hub on the new rovers. without the rings, you usually get a vibe from the wheels not being perfectly centered.
http://cgi.ebay.com/ebaymotors/RANGE...spagenameZWD1V
Old Feb 2, 2012 | 04:05 PM
928paul's Avatar
Default Hubcentric Rings for 19" Range Rover HSE wheels to fit on 2000 Disco II
Hi, what size hubcentric rings should I purchase to install 19" Range Rover HSE wheels to my 2000 Disco II? Is it 72.62mm/70.10mm??
Can I use 14x1.5 wheel nuts?
Thanks a lot!
Vincent@CEC
Mar 9, 2011 05:08 PM
Vincent@CEC
Mar 9, 2011 03:15 PM
Vincent@CEC
Member Group And Special Buys
Jan 4, 2011 05:21 PM
lesliesmukler
Aug 9, 2010 10:40 AM
emxracer
May 1, 2007 11:00 PM
