4.6/hp24 into 4.0/hp22
So what I am hearing on the transmission is that I should keep the 03 transmission AND rear driveshaft. My buddy has the hp22 and rotoflex delete so he will want to keep his driveshaft anyway. Now that I think about it I don't understand why the 03 driveshaft is shorter since it connects to the LT230 and I am sure the LT230's are the same. But it must be so...
front drive shaft is 3/4 in shorter which is why LR list one number for 99-02 and a different for 03/04.
after market companys just dropped that whole part and only sell one size.
if you use the 03 shaft with the 03 tranny should be a problem
but i could be wrong
Okay that explains why, when I have bought driveshafts, I am always asked to measure the length from face to face. I have an aftermarket one (HD, Double Cardan) now, so maybe it will work. I know it has long splines because I accidentally took it apart BRAND NEW OUT OF THE BOX and had to line it up perfectly, then worry about wobble, on my new driveshaft. Thanks for that info. Still confused, though, because I assumed the LT230 would be in the same spot since the HP24 overall length (with bell housing) is the same.
Does the 2000 have SAI? If not, this swap could get a little more complicated, assuming the 2003 does have it (almost all do).
The nanocom can sync the miles too, but they can only sync to the higher of the two stored numbers. In this case, since the vehicle has lowers miles, I'd keep the BCU and cluster the same, and sync the security code between the BCU and the ECM. Unless you just like the looks of the 2003 cluster better, and don't care about the miles being higher than when you started.
Black cannister on left... plumbing on right. SAI?
Yeah, it is SAI.
Since I've never seen that before I am not even sure what it is, but I can Google. Now, how will this complicate things... I have the complete, running donor...
Okay, evolving this post. I see from Roverland:
There are a few different parts on a secondary air injection vehicle that are specific. The fuel pump, engine computer and the cylinder heads are some of the most important. If you have secondary air injection on your vehicle then you must purchase the parts for a vehicle with secondary air injection. If you have secondary air on your engine and have issues with your cylinder heads, you must purchase cylinder heads that are designed for secondary air. Your vehicle is designed for this system. If you purchase non-secondary air injection cylinder heads, they will not work correctly with your vehicle.
So, with a complete donor I will definitely have to swap the ECU (sorry Dusty I didn't know what that was and didn't mention SAI) and fuel pump. No problems with that. Also, alot of parts from my 4.0's won't interchange with this 4.6 setup. Does that ALL sound right?
Yeah, it is SAI.
