Air suspension problems on 2000 discovery II
Old 05-16-2008, 11:47 AM
upstaterover's Avatar
4th Gear
Default RE: Air suspension problems on 2000 discovery II
Sorry I meant "Disco Mike", not Dave
Old 05-16-2008, 12:07 PM
humroot's Avatar
Call Atlantic British at 1-800-533-2210. They can tell you the closest shop that has their LR software. That's how I found mine.
Old 05-16-2008, 12:42 PM
Atlantic British doesn't do that any more, you will just need to find a shop that has something similiar to an Auto Logis scanner, that can help you.
Old 08-16-2008, 03:31 PM
csa02221862's Avatar
My 2000 Discovery II has a slightly different problem. ONLY the left side sinks. Always after 15 min of driving. Let it sit awhile and it comes back up and then sinks 15 min later again. Could this be due to a leak in one bag and then the compressor shuts itself off for protection? It does not sink when left over night in either normal or off road positions. Only when being driven....
I'm suspicious that it may just need to be reset.
What/when do you get the SLS warning lamp? Mine does NOT come on with this problem. Will reading the codes help?
Thanks,
Rich
Old 08-16-2008, 05:48 PM
Whenever it comes to the SLS you need to have it looked at by a shop. Most likly you have a bad height sensor on that side. When it works it air up fine, when it doesnt, well it doesnt.
Old 08-30-2008, 06:58 PM
ronthepoet's Avatar
There's one thing not mentioned in all the posts I've read about leaking air lines, and it's one I've used with some success.
It seems the type of ferrule (brass donut) that they used for the compression fitting is engineered for the PVC (plastic) the lines mount to. As a natural result of time and vibration, they tend to weaken and the fittings invariably begin to leak.
What I did to overcome this issue is to add a touch of GOOP Plumbers sealant (available at ACE and Home Depot) to the line and ferrule BELOW the fitting. Installed before it dries, it creates a very tough seal against the future problems you WILL have if you do nothing.
Just be careful and keep the stuff out of the ends of your hoses! Once in, it's tough to get out!
Ron
DO or do not.
There is no "Try".
-Master Yoda-
Old 07-31-2011, 02:37 PM
yozzer's Avatar
5th Gear
Default air suspension problems help
hi guys im in ireland have problems with my air suspension i got a 00 discovery parked it on a large kerb last week and when i came back one side of the suspension was up and the other was on the bump stops so i changed the air bag on that side and still got no lift at all then i changed around the lines form the valve block and the side that was down went up and the other side stayed down and now both sides are on the bumpstops and wont stay up i think it could be either the valve block or compressor since i have changed the fuze i need all the help i can get on this one was thinking of going to springs but not sure about towing my caravan with them
TRIARII
06-30-2022 09:48 AM
ljdiscovery
02-13-2016 11:21 PM
fastrx7man
01-28-2012 12:49 PM
RoverDude420
02-21-2006 01:02 AM
TonyKart95
12-13-2005 03:01 AM
Quick Reply: Air suspension problems on 2000 discovery II
