Brake Master Cylinder problem
I just replaced the Brake Master Cylinder on by 2003 Disco II
I can't figure out what is going on? I can't get any fluid to flow from the master cylinder to the ABS box? There are no valves, or any obstructions between the output of the brake master cylinder lines (2) on the inboard side of the cylinder and the ABS box but when I pump the brakes there is no flow whatsoever from the cylinder out those tubes. I have the input lines disconnected from the ABS and a clear line and have drawn a vacuum on the line and it sucks brake fluid from baster cylinder reservoir to the line? It seems there should be easy flow every time I pump the brakes but nothing comes out the tubes when I pump the brakes? When I do push in on the brakes there are bubbles that come out of the small hole in the bottom of the brake reservoir every time I push down. What am I doing wrong.
Brake Booster exploded view - pin now not connected?
However, I may have messed something up in the process. The Pin was just laying there and there is a "star" type attachment ring that isn't attached to anything and I can't figure out what it attaches to and how? Attached are pictures.
Does anyone have an exploded view of the brake booster portion where the pin is located. I'm afraid something may have fallen off the pin and is now inside the brake booster - there is room for it too fall through the springs and rest inside the booster. If it's magnetic maybe I can fish it out with a magnet?
Any help with how the pin attaches inside the booster (if it does) or what its supposed to attach with would be appreciated.
Thanks - got it sorted with some help from this forum
Thanks. With all your help and some special help from the folks at Lucky8LLC I got it sorted. What I was worried about was whether there was another part or something that might have fallen into the booster. They pulled a booster from their stock and looked it over and sure enough, just the star clip snaps in to hold the plunger. I fiddled around and got the star to snap in and all is well. I still have a little bleeding to do to get things back to full firmness but that will have to wait a few days.
Thanks again and a special thanks to Lucky8 for taking the time to get "eyes on" the the real thing to be sure.
You gotta love the parts guys that are truly customer service oriented and willing to do things like this knowing they aren't making a dime from the time spent. It's hearing stuff like this that make you know they are willing to go the extra step.
I almost called them about my steering issue this weekend, but I knew they were out "training"
