Brake problems, almost had an accident
Old Jan 20, 2012 | 08:29 AM
hhalimi's Avatar
Default Brake problems, almost had an accident
I was driving around 25m/h, when a car suddenly braked in fron of me, I had plenty of distance, pushed the brake harder than normal but the pedal was feeling very mushy and the car stopped just inches away from the other car. I had to push realy hard and it was feeling as if the brakes were not working well. I have put around 400 miles on this car and in normal driving condition, it never gave me a feeling as if there was any problems with the brakes. I hope the brake booster is working. I am planning on doing some hard braking, when the trafic permits to make sure every thing is working. Brake fluid level is good. I did not get to bleed/flush the fluid yet. Any other ideas, or this is normal?
Old Jan 20, 2012 | 08:38 AM
drowssap's Avatar
did you try pumping them at all to see if it improved ?
Old Jan 20, 2012 | 08:42 AM
What year is the truck, how many miles on it, when was the brake system last flushed?
If the fluid is brown, do a full 2 quart DOT 4 brake flush, inspect the brake pads for being thin or cracked and do you have any warning lights on?
Old Jan 20, 2012 | 08:44 AM
hhalimi's Avatar
At that moment, no, but later yes and seems to make the pedal feel harder.
Old Jan 20, 2012 | 08:48 AM
That is normal. Now back to my questions?????
Old Jan 20, 2012 | 08:52 AM
hhalimi's Avatar
It is 04 with just over 126k miles on it. Brake pads and rotors have been changed within the past 2 years, the system has not been flushed since the car had around 40K miles on it, when the second owner bought it. It might not have been flushed before that either. I do not have any warning lights, except the sevice engine soon light after power wash and induction cleaning.
Old Jan 20, 2012 | 08:55 AM
So, start with the brake flush using Castrol's synthetic brake fluid, then get back to us.
Old Jan 20, 2012 | 09:27 AM
hhalimi's Avatar
Thank you Mike.
It is very cold here, I will probably freeze in my garage if I do it my self, I am going to get the castrol brake fluid and a code reader and go to the closest mechanic to flush the system and also inspect the brakes.
Old Jan 20, 2012 | 10:10 AM
discotheque's Avatar
Would you mind posting how much you paid when you get it done? Thx
Old Jan 20, 2012 | 10:25 AM
Don't go buy a scanner unless you plan on using it a lot and then talk to me first on what to buy and from where.
A shop will charge you $100 easily to bleed the brakes, sure you don't want to do them yourself?
