disappearing coolant
on
I have an 02 Disco that is presenting an odd problem to me. After being away for the weekend, I picked up my disco and before driving off I noticed the expansion tank was almost empty. When I was parked Friday night it was full. I've made a habit of checking the coolant level almost daily due to the horror stories we all see daily. I've got no leaks externally. No coolant in the oil. No boiling. No overheating issues. None of the classic signs of hg failure. I performed 3 block tests which all showed no leaks (chemically). Anyone else had similar symptoms?
on
on
...and that would be the Mars Rover and I wouldn't want to mess with him
I'm sorry to say this is may be a symptom of a blown head gasket. If the front or rear of the gasket blows, it will leak coolant but the coolant won't get into the oil or vice versa.
Lay underneath with a flashlight and examine the front and rear of the heads. I bet you'll see a trail of coagulated coolant (especially if you are still running dexcool).
