P0441 & P1590
Old Jul 25, 2008 | 07:58 PM
brooksa's Avatar
Default P0441 & P1590
Need some help on two codes:
P0441
Evap Purge Valve Incorrect Flow Fault
P1590
ABS rough road signal circut malfunction; Hardware is ok, but SLABS ECU is sending an error
Old Jul 25, 2008 | 09:18 PM
Default RE: P0441 & P1590
Loose/bad gas cap.
Bad ABS sensor.
These codes have come up before and I am 90%, ok 80% that these are the problems.
I am sure that DiscoMike will chime in with a better and more accurate answer than me. Take his answer over mine.
Old Jul 25, 2008 | 09:22 PM
brooksa's Avatar
I was thinking that but good to have more opinions, thanks
Old Jul 25, 2008 | 09:26 PM
Because the EVAP system is a closed loop and the gas tank is part of that loop a loose/bad gas cap will set off emission codes.
And the SLABSECU is the second longest lasting part on your Rover, the check engine light bulb is the longest lasting part on any Rover.
Draayer
Aug 29, 2012 09:10 PM
DV57
Mar 2, 2012 06:03 PM
baburhan
Oct 2, 2010 03:23 PM
Danny Lee 97 Disco
Aug 1, 2010 11:14 PM
Nitro96
Jan 5, 2008 10:45 AM
