One Headlight getting dim...
ive swapped bulbs and the side that was dim stayed dim after the swap... so i could have a poor gnd. I have looked over electrical diagrams in the RAVE and I cant make any sense out of it.... where are the headlight grounds... or should I replace both headlight bulbs and what are a good replacement for factory bulbs, im thinkin halogen..... anyone run Silverstars?
Your headlight grounds are on the inner fender on each side. Check next to the battery for the right headlight and by the jack for the left. That's the best description I can come up with of where they are based on the RAVE manual. The ground for the RH headlight is C0559 and LH is C0564. If you go into RAVE and click on connector, then click on those numbers it has a picture of where they are.
Halogens will go right into the factory bulb conector? just to see if i want them... and i need a kit to upgrade to HID right? i would love to upgrade from factory the headlamps and fogs
thanks for the gnd. location, I'll check it out tomorrow...
LANDZUII- I did the bulb swap...thats how i know it isnt the bulb. prolly like Spike says the connection may bad, if thats good then i must check grounds, inspect wiring and such...
