Removing viscous fan
So I'm getting ready to disassemble my cooling system on Friday and it seems like it would be much easier if I removed the Fan. However the workshop manual specifies that I should remove it using some special tools "LRT-12-093" and "LRT-12-094" Now I'm a fan of using the right tool for the job, but these don't seem like they should be necessary.
Can this be removed using normal wrenches or am I missing something that is going to bite me when I go in there?
Thanks in advance!
Thanks in advance!
RE: Removing viscous fan
Okay, so I have a crescent wrench that fits the nut, no problem there. What did you do to keep the assembly from spinning? I tried stopping the belt, but the pulley just spins without moving the belt. I bent a screwdriver trying to jamb it between a bolt head and the pulley, and now I'm out of ideas except to get the tools.
(I've looked into the rental places and no dice)
Anyway, thanks for the help already given. I'm in the ready to re-assemble stage, I'd just love to replace that water pump since I've got the parts and got the system drained.
air chisel with a flat blade placed carefully on the nut will spin it right off... every time..
but, probably bad for the water pump bearings. Always try and do it with a fan wrench set first, i'm pretty sure one from a dodge 3.9 fits (i used the one from my old dakota.) Autozone will loan it to you for a deposit if you don't want to buy one.
Quick Update...
Well, I had no luck with the tool from Autozone, the wrench was too large. I decided to put it back together for now without the new waterpump to see if it was still leaking. I was stuck anyway, because I was waiting for a new-style upper hose set. Anyway, back into it...
This time, I rented a different set with a 36mm wrench from Advance Auto, and the fan came off easy. Woo Hoo! Thanks for all the help and suggestions. The key is to have the right tools because, for me, there just wasn't enough room for the crescent wrench. So, if anyone else does the job, I suggest the set from Advance Auto.
