Forum Help & Suggestion Center This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
Discovery II Four wheel question
Old Jan 23, 2011 | 03:39 PM
buck1x's Avatar
Default Discovery II Four wheel question
I may have nothing wrong. On ice, low range, 1999 Discovery II, sudden acceleration will spin the front and rear wheels. Same situation, in High range only the front spin. Shouldn't the rear try also? Sudden braking on ice slides the wheels without the ABS shudder I am used to with other vehicles. Does this sound normal for the Rover?
The high to low range selector was stuck in high but it seemed to be just never used. Once I got it to work, it is improving each time. Will clean and lube and sure to improve. Did not change the wheel spin situation.
I am new to Rovers but not uncomfortable with repairs. Did the head gaskets, found the hose vent issue already.
Britchick1980
Mar 3, 2015 05:45 PM
archaeology_student
Jan 29, 2015 01:31 PM
Meterman
Oct 8, 2013 11:42 AM
BENROVERN
Nov 5, 2007 09:19 AM
Landzu
21
Jun 11, 2006 05:23 PM
