Freelander Talk about the Land Rover Freelander within.
Air Con Wiring Diagram
Old Aug 14, 2009 | 12:33 PM
disco933's Avatar
4th Gear
Default Air Con Wiring Diagram
Does anyone hve a wiring diagram for the air con system of a 54 plate TD4 SE. I have been told the problem is the compressor, but would like to check wiring.
Old Aug 14, 2009 | 01:26 PM
You might see if you can download a Rave Cd, not sure if they have a PDF file for a Freelander.
What is your a/c doing?
Old Aug 14, 2009 | 06:35 PM
roverguy7's Avatar
dont quote me as we dont have desiels in the us, but here, its just a straight ECM relay that gives power, case ground
Old Aug 16, 2009 | 02:26 AM
disco933's Avatar
4th Gear
The air-con was re-gassed by my local garage, then they discovered it would not work as the fuse had been removed. Took it to an auto electrician who says he can hear compressor operating the clutch but is not holding!!!!!!!!
I spoke to a friend who suggested checking relays. the horn relay is the same and I swapped then but without a diagram don't actually know what operates the relay.
Have tried downloading Rave Cd but having problems opening it, thanks for the suggestion.
Barry semi retired ex BT Service Manager.
ex Series 3 2.25 petrol, ex 3.5 V8 Rangie, ex 200Tdi Disco, ex 300Tdi Disco, ex 4.0 V8 LPG converted Rangie.
Old Aug 20, 2009 | 06:26 PM
roverguy7's Avatar
if the clutch is engaging, then you dont need to worry about what controls the relay, but why its not catching. try taking the clutch off and putting it back on... see if theres a spacer behind it... you also need to make sure the compressor is not locked up
RANGER46
Nov 29, 2008 02:09 PM
snowdude
Sep 3, 2008 03:52 PM
specky
Mar 23, 2008 06:51 PM
skewett
Jun 3, 2007 08:15 AM
littlemissdisco
Feb 21, 2007 06:32 PM
