Freelander Talk about the Land Rover Freelander within.
starting problem
Old Jun 16, 2009 | 08:50 AM
alan46's Avatar
Default starting problem
Hi i have a freelander TD4 GS 2001,it starts 1st time every morning yet if i go on a short journey stop turn off an return half hour or hour later it w'ont start, i then have to leave it 15 mins or up to an hour then it will start no probs always ok when on a cold start, any ideas its very frustrating HELP
Regards Alan
Old Jul 20, 2009 | 08:24 AM
Smithsmaville's Avatar
4th Gear
Hi Alan i have a 2000 td4 Freelander also with the exact same problem. I had mine looked at and it had no fault codes or anything. The mechanic had it for a few days and found it difficult to get the car to fault at first as onece running it does not skip a beat. Its only when it has stopped after a short journey and a quick return it will turn over and not fire. Does your heater light come on all the time or is it intermittent like mine? Mine will sometimes not light up at all but still start and then next day they will light up like a xmas tree. If you find a cause would be grateful if you let me know.
Darrell
Old Aug 8, 2009 | 06:10 AM
4th Gear
Alan
I have recently had my car repaired at a land rover specialist. It had the same problem as you described.
Fault repaired was a camshaft sensor that would allow it to start a few times but would then not read the signal.
Cost of repair £151.00 well worth the money for peace oif mind when going out to the car to start it and it goes everytime.
Hope this helps if you have not had yours repaired yet!
Darrell
Old Aug 21, 2009 | 05:38 PM
hateroffreelander's Avatar
Default Freelander Ignition Switch
I have a 2003 freelander that when I changed the Spark Plugs, will now not start. When I turn the Ignition Switch it does absolutely nothing. I have checked the Starter, the Plugs, the Relays and now I noticed that the Ignition Switch is very hot when I turn the key several times. This was happening before all this happen, when I removed the key from the ignition my key would be very hot. I need help in instruction in how to removal the entire Ignition Switch from the vehicle ? Someone please help ?!
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
djaaronreed
Dec 7, 2013 11:01 AM
brian.arthur
Freelander
Mar 14, 2006 04:32 PM
finetrophywife
Aug 2, 2005 01:43 AM
asmcmillin
Apr 10, 2005 12:16 AM
