Freelander Talk about the Land Rover Freelander within.
F 4 flashes on dash
Old Nov 19, 2009 | 01:54 PM
Rayyag's Avatar
Default F 4 flashes on dash
Hello I have an 03' freelander and as I was driving yesterday the car felt as if it jumped and then on the dash where the milage and gear the car is in can be seen, the letter F and number 4 flash back to back until I turn the car off, also the truck symbol and an exclamtion mark show up too. What could this be?
Old Nov 21, 2009 | 01:33 AM
wilsonjohnr's Avatar
6th Gear
are you cereal right now?
Old Dec 3, 2009 | 11:23 AM
Rayyag's Avatar
Hello, I am not sure what that means?
Old Dec 4, 2009 | 06:42 AM
Rhino1's Avatar
Okay, not sure if this will help, but similar problem happened on my 02 Freelander..the "F" should stand for "Fuse". And if this is correct the 4 could mean a number of things..As per my RAVE manual, here goes:
Could be:
1. A/C compressor clutch relay
2. E-box temp. sensor
3. Cooling Fan Unit
4. Steptronic switch
5. Gearbox Selonoid
6. Illumination Relay
7. Automatic Trans. Control Unit
Hopefully this will help, other than that i would take it to a dealership or LR type repair facility that has ODB.
Cheers!!
Old Dec 8, 2009 | 11:51 AM
cubconcli's Avatar
I accept with information:
1. Cooling Fan Unit
2. Steptronic switch
3. Gearbox Selonoid
4. Illumination Relay
Old Dec 12, 2009 | 02:18 PM
Rayyag's Avatar
Thank you all!
Old Apr 11, 2011 | 12:35 PM
1sweetryd's Avatar
Hello, seems my 03 landrover is doing the SAME thing, did you ever figure out what was the problem? I'm stuck at the moment... Can you help??
bribake
May 6, 2007 03:51 PM
Yetielliott
Mar 14, 2005 05:15 PM
duoglide98
Mar 7, 2005 08:26 PM
nick1996rover
Feb 12, 2005 12:46 AM
racdisco
Feb 10, 2005 04:37 AM
