LR2 Rear Differential Bearing Failure 69k Miles
Just got diff replaced, started whining at 80K, but didn't get it replaced until 88K.
About $2900 at the dealer. They replaced the entire unit, it looks like the old style diff on the outside but the rep said the original diff was actually NLA and this is a new part number so hopefully it has better bearings.
Revisiting. New R. Diff @ 88K is still doing fine at 126K.
Doing a lot of research online seems like the original problem (weak design + software) is seriously aggravated by the LR maintenance schedule. Volvo uses a more aggressive schedule for most of these items. LR considers the Haldex to be a (very) expensive consumable, but Volvo has scheduled Mx!
Consensus seems to be that these items need to done at these intervals:
Tranny Fluid: 50K/5 years
Transfer Case (PTU) Oil: 50K/5 years
R. Diff Oil: 40K/5 years
Haldex Oil, Filter, and Pump filter: 40K/3 years (fluid is hygroscopic, like brake fluid)
Haldex should be removed to service, to allow a thorough cleaning, although you may be able to do fluid/filter in place. A shop in the UK recommends Haldex fluid/filter @ 20k, thorough cleaning @ 40k.
How-to's are available on a variety of forums and youtube.
You can drill and tap holes for drain plugs in the Transfer Case and R. Diff., makes it easier to drain.
Good luck.
Good luck.
Good luck.
Good luck.
I had no idea this was a Haldex system. I guess I'm used to seeing the external electric pump and controller on my Audi/VW's. I didn't notice the pump on my LR2 maybe it's not visible from the back.
No wonder this thing failed you can't run a haldex system for that long. It's like not changing your engine oil for 100k miles. I change the Haldex fluid/filter/screen every 20K miles on my Audi's. If this is like Audi\Volvo then the Haldex service is pretty easy. I just did my S3 at 18k to see how the screen looked. The job took less than a 1/2 hour.
I'm not familiar with the newer models.
