Spring Conversion
Old Aug 29, 2009 | 04:23 PM
CampCobb's Avatar
Default Spring Conversion
2000 Discovery II with 89k miles
I am preparing to purchase a spring conversion kit to replace rear air bags. How important is it to replace shocks?
I believe this kit http://www.roverparts.com/Parts/9268D2ABP.cfm?bc=ab has everything I need.
Old Aug 29, 2009 | 05:04 PM
Very important, especially if they are still factory.
How many miles on your truck? Specifically what springs are you wanting to install, the wrong one can lift the truck too high or not high enough.
By the way, why are you replacing the SLS instead of fixing it?
Old Aug 29, 2009 | 09:04 PM
CampCobb's Avatar
89k miles on the vehicle
http://www.roverparts.com/Parts/9268D2ABP.cfm?bc=ab are the springs I am thinking of buying.
SLS seems too unreliable. They are deflated. Pump not working at all. Very disappointing for a vehicle with only 89k miles. One simple fix (springs) no more issues. Well, plenty more issues, it is a Landrover, but just no more with the air bags.
Old Aug 30, 2009 | 07:57 AM
Should have asked first, I could have walked you thru the SLS issue.
At your miles, you would be a lot better off installing a Old Man Emu kit front and rear along with the adapter kit to convert the rear mounts to coils. Doing this will give you a much better ride, a more level and equal ride cause your current front springs, steering stabilizer and all 4 shocks have long since warn out.
southfloridadiscoII
Jun 18, 2009 08:48 AM
humroot
Nov 27, 2008 01:26 PM
lonely king
Aug 5, 2008 02:26 AM
steve125
Member Group And Special Buys
Jun 21, 2007 11:09 AM
landbeater
May 5, 2007 01:24 PM
