ECM wanted or help?
Old Nov 7, 2011 | 06:29 PM
mat231v6's Avatar
4th Gear
Default ECM wanted or help?
what i am looking for is a ECM for a 1991 land rover range rover. has a 20 code that wont clear. i did everything in the book, so i am guessing its the ecm. tell me how much you want plus shipping.
(if any one know how to fix it that would be great. the service engine light wont go out. )
Old Nov 8, 2011 | 10:23 AM
Lincoln Tarantino's Avatar
Do you have the part #?
Thanks
Lincoln
Old Nov 10, 2011 | 04:42 PM
mat231v6's Avatar
4th Gear
Thanks
Lincoln
Sorry sir I do not.
Old Nov 11, 2011 | 05:16 PM
I think I have a couple of them here, but need to make sure it will work on your truck. Is it the fuel injection ecu? wabco brake ecu? etc....do you have a pic of it?
Thanks
Lincoln
Old Nov 12, 2011 | 08:48 AM
You will most likely need the BCU from the same doner truck or you will not be able to start the truck.
Old Nov 12, 2011 | 07:26 PM
mat231v6's Avatar
4th Gear
Thanks
Lincoln
its FI...
Old Nov 13, 2011 | 03:24 PM
Paul Grant's Avatar
If you are looking for the ECU that controls the fuel injection system in your truck, ANY 14 CUX ECU will work just fine. That means any ECU from 1990-1995 including units found in DI's from those years too. You won't need a BCU to work with it. They are all plug and play. Doesn't matter if it's from a 3.9L or a 4.2L they will all work. They also are pretty cheap these days because you're talking about an electrical component that is between 17 and 21 years old. They're all looking pretty long in the tooth these days.
Old Nov 14, 2011 | 08:47 AM
Default ECM hel
I have 1 FI ECM out of a 94 d1. Make me a Fair offer and it's yours.
Thanks
Lincoln
Landroverboneyard.com - Roverbones home page
Old Nov 15, 2011 | 07:17 PM
threalassmikeg's Avatar
If it's the RED serice engine light thats on you need to reset or unplug the
service interval reminder...it's under the passenger seat it brown and has a land rover
decal on it, just unplug and remove it.
couldn't find a f/c 20 and honestly dont remember.
Take a photo of the white 14cux obd1 connector and either post it or pm me with
it. You may need to add a jumper wire to that connector to clear the code.
Old Nov 17, 2011 | 05:10 PM
mat231v6's Avatar
4th Gear
i will have to take a picture. i did unplug the ECM and the light is still on. i went on ebay and found a ecm so i will try that.
Chris-bob
May 9, 2011 02:28 PM
Jull
Feb 8, 2009 09:41 AM
tommia4
Feb 3, 2009 07:06 PM
hoberock
Jan 18, 2007 06:19 PM
riebs
Oct 7, 2006 02:15 PM
