ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
What did you get done this week?.....
Old Nov 1, 2011 | 09:27 PM
  #61
nahtanoj's Avatar
Originally Posted by mln01
Saturday and Sunday
  • '04 CDL ($75 from local salvage) Yippee!
  • Standard size lighter
  • Heated seat switches ($10 local salvage)
what a deal on that CDL. i need to start hunting for one soon. my list is too long.
Old Nov 5, 2011 | 07:29 AM
  #62
threalassmikeg's Avatar
you guys got it all wrong...
Replaced headliner in my 02 D2, Alternator in my P38, Detailed not so new 04 D2
Old Nov 6, 2011 | 08:10 PM
  #63
atancreti's Avatar
I managed to create a coolant leak. I think its the valley pan. I posted the pics and all in the D I tech section. AS IF I NEEDED TO CAUSE ANOTHER LEAK...
Old Nov 9, 2011 | 12:19 PM
  #64
yloDiscoII's Avatar
We didn't have it wrong, we were celebrating with a mariachi band that the Three Amigos were gone. Now that you've posted that picture, you have cursed that whole board
Old Nov 9, 2011 | 03:03 PM
  #65
yloDiscoII's Avatar
BEFORE...
Originally Posted by yloDiscoII
Received my winch tray
DSC_0194-2.jpg?t=1320202699
AFTER...
DSC_0199-2.jpg?t=1320872458
Old Nov 9, 2011 | 03:22 PM
  #66
Banzai Jimmy's Avatar
Finally tracked down why my washer fluid was leaking (went too long without looking into it). First, the nipple on the headlight washer fluid pump was cracked so badly that it snapped completely off when removing the tank. So, I filled the hole in the pump with some two-part epoxy. Didn't need that anyways. So I fill up the tank with fluid figuring I fixed it just to have fluid dripping away onto the ground. Off comes the tank again to find that the one-way valve for the windshield line is leaking. The top popped right off of it, so I wiped it completely down getting all the dirt and crud off of it, slapped some super glue on the lid (turns out that the lid/top doesn't just snap back on), and popped it back together. Initial indications are that it isn't leaking and fluid is reaching the windshield. I'm ready for winter and the magnesium chloride they spray on the roads.
Old Nov 12, 2011 | 02:57 PM
  #67
dgi 07's Avatar
Four fresh General Grabber AT2 Tires. Looks nice and mean. and ready for the snow.
Sylvannia Silverstar bulbs. God these things are brighter than my regular bulbs. Now to change out my fog light bulbs to yellow.
Old Nov 16, 2011 | 04:04 PM
  #68
Chris-bob's Avatar
Changed the water pump and t-stat housing octopus thingy on my buddies '05 LR3.
Old Nov 16, 2011 | 04:10 PM
  #69
yloDiscoII's Avatar
Thumbs up
What a good friend
Old Dec 3, 2011 | 01:35 PM
  #70
fishEH's Avatar
Found my front wheel bearings to be horribly loose! Thought I was gonna get soaked on new bearings but Napa had the Timkens for $7.63 each!!! Replaced and repacked bearings on the front. Removed mud shields from the front. Also found one of my TRE's loose. Added a washer and retightened. Removed disc weight from front diff. Removed rear door tire carrier in preparation for my swing away tire carrier.
