ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
What did you get done this week?.....
Old Feb 8, 2012 | 11:33 AM
  #81
yloDiscoII's Avatar
Finally killed my front drive-shaft! According to service records I have, this is the shaft from the factory, made it 137K!!!
Old Feb 11, 2012 | 07:49 AM
  #82
mln01's Avatar
Wrapping up the 120k service. We've pecked away at the list over the last month. Nothing exceptional about that by itself, but the fun part has been that I've used the 120k service as an opportunity to teach auto maintenance to our 16-yr old son who now drives Redrover to school daily. He did the oil change all by himself Wednesday.
Old Feb 11, 2012 | 06:10 PM
  #83
dgi 07's Avatar
Water pump, rear wiper, trans mounts. On tap for next week is motor mounts, coolant flush round 2 and ignition wires. And a trans service.
Old Feb 12, 2012 | 08:45 PM
  #84
honda50r's Avatar
I dropped my oil pan this weekend and cleaned up my pick up line.
Old Feb 13, 2012 | 11:32 AM
  #85
turf63's Avatar
sat i added +2" britpart SS brake lines and did a (one quart) brake fluid flush (mike, dont yell at me). I planned on getting a camel cut and relocating my axel breathers done on sunday, but it snowed and it was cold, so i took tin snips to my rear QP's and called it a day. they look like ****, but they did before too when they were all bent up from my tires smashing into them
Old Feb 13, 2012 | 12:11 PM
  #86
yloDiscoII's Avatar
Scored a T-Case/Linkage out of an '04 (Schwing!), got a rebuilt prop-shaft in from Columbia Rovers.....so I didn't get anything done...except spend money.
EDIT : Prop-shaft is installed and now she's rolling silky smooth
Old Feb 17, 2012 | 04:05 PM
  #87
turf63's Avatar
Dgi: good luck with the trams service. Hopefuly it goes better than the three times I tried. Gotta drop the ypipe to drop the pan. IF you can get the x member out
Old Feb 29, 2012 | 11:36 PM
  #88
sclarkie's Avatar
Well, I figured I'd jump in here- over the last couple weekends, I've replaced the gear oil in my transfer case with 85w140, which really seemed to quiet things down; same oil in the diffs too- went in the water in Charleau Gap, so I figured it couldn't hurt to change it. Also had a buddy fix some broken welds on my roof rack and re-mounted (bulletproof now); flushed and bled the brakes (so much conversation on that in here- I use a mason jar and a piece of tubing and it works like a charm); changed the oil & filter, installed a new to me rear sway bar (thx Paul)- it was great off road with none, but a little tippy in the corners on the street before; dropped in a new Optima yellow-top. Tomorrow is a new set of plugs and my new set of 8mm Kingsborne wires. next on the list is to pull my wiper washer pumps and try to get them working again, and replace the tubing; then start pulling my rear door apart to find out why the window won't move (switches work when I swap them around, and I could find no broken solder joints on the ECU). AZ Land Rover Rally is in a little over 2 mos- gotta be ready!
Old Mar 1, 2012 | 05:20 AM
  #89
dgi 07's Avatar
Thanks brother. I didn't end up doing it. Got caught up with the engine mounts. Those things are a pain in the left ********. Found the cause of my vibration though. Stupid engine mounts.
And did some KB spark plug wires.
Old Mar 2, 2012 | 06:14 PM
  #90
sclarkie's Avatar
Plugs and wires in, new fuel filter... runs like a dream.
