ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
White Shepard
Old Jan 24, 2011 | 06:55 PM
salve7's Avatar
I just used it on my subaru and it worked like a charm on the crankshaft and camshaft seals. I had them replaced only to have another leak spring up so Im going to do it again. I have never heard of a problem with people using it more than once... have you?
Old Jan 24, 2011 | 07:07 PM
No I have not heard of any one having a problem using it more than once.
Old Feb 22, 2011 | 04:46 PM
salve7's Avatar
Well I used it again and it didn't work but they are on top of things when it comes down to the guarantee. Hopefully they will send me either my money back or another bottle because I will def use it again.
Old Mar 20, 2011 | 06:49 AM
1thunder's Avatar
4th Gear
Default oil fluid leak
Novice here. HAve a leak over the muffler plate and spraying to side of passenger rear door. Front of truck very clean and dry. Where would I add the White shepards? Do I need a lift to add it to the transfer case fluid?
Thanks
Originally Posted by Disco Mike
It is one of the best oil/hydralic stop leaks I have ever used.
Old Mar 20, 2011 | 09:37 AM
I have been promoting most of their products for the last few years, only after using it in my p/s t/case and rear diff and it works real well.
I do though, suggest to not use any of their or any other companies products to stop a coolant leak.
drowssap
Jan 24, 2012 05:19 PM
CarolynS
Jun 11, 2011 03:31 PM
discoboy
Oct 8, 2010 11:55 PM
Sights N Sounds
Mar 9, 2006 12:42 AM
englishboyonice
Mar 28, 2005 08:41 PM
