How to: DI viscous fan clutch removal
Old 12-23-2009, 12:26 PM
BajaXJ92's Avatar
Default How to: DI viscous fan clutch removal
Thought I'd do a little write-up since mine gave me some trouble....
Tools needed:
-Large adjustable crescent wrench or 32mm open end wrench. There is also a specialized wrench available online.
-Vice grips
-Large pry bar
Clamp the vice grips to the pulley, slip wrench onto fan clutch bolt, and use pry bar to keep pulley from turning while you're applying torque to the fan clutch bolt.
Insert pry bar between vice grips and pulley.
I would recommend putting a rag over the end of the pry bar as to not indent or scratch the pulley, or even put a hole in your serpentine belt. Apply torque to fan clutch bolt counter-clockwise.(if facing the front of the vehicle, you'll be turning your wrench to the left or passenger side)
Remove old clutch from fan.
Replace fan clutch with new hardware.
Simply reverse the process to tighten new fan clutch down. Hopefully your viscous fan clutch bolt isn't as much of a bear as mine was!
-Adam
Old 12-23-2009, 08:37 PM
Thank you for this write up, very simple to do and great pictures.
Old 12-23-2009, 08:38 PM
Looks like you and I have the same drop light.
Old 04-06-2010, 05:50 AM
David Kadasia's Avatar
Default thanks
Played with this problem today.....good write up. Shall give it a try tomorrow.
Old 04-19-2010, 05:01 PM
thehulk's Avatar
Is this the same process for a d2? I thought they were reverse threaded...
DiscoNewbe (06-07-2020)
Old 04-19-2010, 05:44 PM
ColoDisco's Avatar
I just did my water pump. Did not think to do a write up. My fan was a huge pita as well. I used a large set of channel locks, large adjustable wrench and persistance.
Old 04-19-2010, 05:50 PM
Thermal1's Avatar
If you have air tools, a air hammer is a great way to bust that nut loose. You will tear up the nut - but that is ok
Old 08-03-2010, 08:35 AM
WinkeFett's Avatar
4th Gear
Default same for the DII? i have a 2003 SE
is this the same process for the DII? i saw someone already asked about it, however, i didn't see a response to it. i didn't want to try it myself until i was sure it was the same process since i've heard removing it is a huge PITA. please let me know!
also, has anyone kept a fan on their discovery with a small nick out of one of the blades? my nick is so small that i'm not sure it is hurting the balance or not and if it's not killing my water pump, i'd rather not replace the 260 dollar all-in-one fan/clutch. oh, also, the nick in the fan blade has apparently been around since i bought the truck 10,000 miles ago.
Last edited by WinkeFett; 08-03-2010 at 08:37 AM. Reason: udpated info on mileage when fan was nicked.
Old 08-03-2010, 09:01 AM
Bundu's Avatar
Banned
The D2 takes a 36mm wrench. See if you can lock the pulley somehow and break the nut free. You get a fan clutch tool at Advanced, one piece is the 36mm open wrench and the other piece hooks over the pulley shaft and catches a bolt head on the pulley - hold the pulley still and undo the fan nut counter clockwise when facing the engine. The smaller piece takes a 1/2" ratchet or breaker bar. It's easy to get off with the right tools.
http://shop.advanceautoparts.com/web..._T|GRP2083____
Old 08-03-2010, 10:04 AM
dcarr1971's Avatar
Originally Posted by Bundu
The D2 takes a 36mm wrench. See if you can lock the pulley somehow and break the nut free. You get a fan clutch tool at Advanced, one piece is the 36mm open wrench and the other piece hooks over the pulley shaft and catches a bolt head on the pulley... ...It's easy to get off with the right tools...
+1 on having the right tools!
Some auto parts stores also have loaner/rental tools. If you go that route and use loaners, make sure you measure the 36mm wrench to make sure that it is still 36mm. I think some Fords may also use the 36mm, so the loaner tools get a lot of use. I've had several sets where the 36mm was stretched or worn out to 38-40mm...being off by this much will make it really tough to get the fan clutch loose.
IMHO after having trouble with the loaner tools, if you think you're keeping your DII for the foreseeable future then spending the $25 on a 36mm fan clutch wrench probably isn't a bad investment.
Quick Reply: How to: DI viscous fan clutch removal
