Suspension sponsored by Arnott Inc. Talk about your suspension within.
air susp gone?? is it worth repair or convert
Old Jan 21, 2008 | 10:51 AM
roverrick's Avatar
Default air susp gone?? is it worth repair or convert
I figured out that I had a front and rear air susp on the same side leaking. I bought the air susp bags. I was going to replace them today and i went to the AFC game yesterday Pats won again!!!! The rover was packed w/4 guys and tailgate stuff. On the way to the game the susp dropped and i couldn't hear the pump anymore. Today I checked the relays under the pass front seat and I appears I'm getting power to the pump (I hear clicking from the boxon the frame rail.) Is there a relay or anything there or is the pump smoked. If so I'll have to convert to springs for cost reason I need some help. Thanks in advance Rick
Old Jan 21, 2008 | 12:57 PM
Default RE: air susp gone?? is it worth repair or convert
You need to go to a shop that has the proper scanner and have them read for codes to know for sure.
Old Jan 22, 2008 | 02:07 PM
roverrick's Avatar
Hey Mike I reluctantly am going to convert over to coil springs. It is just a cost issue and down time. Rick
Old Jan 23, 2008 | 10:43 AM
You are only dealing with an electrical issue.
Old Jan 29, 2008 | 09:34 AM
Charles68's Avatar
Hi,
2001 Disco II with about <70k and rear air suspension failed again. This is second time. It was truly sad to look at the 'canyonero' dragging its *** like that.
Waiting to hear from indy mechanic on what problem is. I need to dodge some bullets on this because budget too tight. I'm afraid its gonna be a big bill.......
Does anyone (Mike?) have advice on how to clearly diagnose problem?
Thanks for help.
Old Jan 29, 2008 | 11:46 AM
Find out exactly what is wrong, get an estimate and call me. Many times they can be fixed real inexpensively.
What exactly is it doing wrong?
303-862-7680
Colorado before 8 pm
Old Jan 29, 2008 | 03:26 PM
Charles68's Avatar
Mike, Thanks for help today. They found problem and fixed. I forgot name of partbut something electrical - sounded like a wire or sensor or something). $134 total and suspension is fine (knock knock knock).
Old Jan 30, 2008 | 04:52 PM
We like to hear that, sounds like you lost a height sensor.
Old Jan 30, 2008 | 05:34 PM
ajh's Avatar
ajh
I found handling improved dramatically when I put springs in the back, a whole lot less uncontrolled sway back there. I would certainly never go back to a pistonless airbag system again.
Old Feb 4, 2008 | 07:36 PM
roverrick's Avatar
I changed over to the coil springs. My pump was gone. The ride is a little different. I liked the air susp. but it was to costly. Rick
timelessride
Aug 11, 2008 06:23 PM
Charles68
Mar 13, 2008 11:09 AM
roverrick
Jan 8, 2008 01:22 PM
roverrick
Jan 8, 2008 01:10 PM
OzRRS
Mar 29, 2006 11:16 PM
