Suspension sponsored by Arnott Inc. Talk about your suspension within.
Rancho x vs. Ome ltr vs. everything
Old Jun 22, 2008 | 02:21 PM
rwarren92's Avatar
Default Rancho x vs. Ome ltr vs. everything
Rancho 9000x vs. OME LTR which one is better Vs. any other brand or model you can come u with
Also Rover tym vs. ome springs
i have disco 1 97' 235/85/16 bfg mt andexcept for having to replace almost everything under the hood except the engine its pretty much stock i would like to get at least a 2 inch lift post your opinions thanks warren
Old Jun 22, 2008 | 02:23 PM
rwarren92's Avatar
Default RE: Rancho x vs. Ome ltr vs. everything
ive heard procomps and big blue had a shotty rep
and what is the essential componets recommended to get along with a lift
Old Jun 22, 2008 | 08:03 PM
If the brake lines haven't been done I would get new ones as well.
If you stick with 2 inches that's about all I would worry about.
If you go to 3" then I would add along list to that.
I have 3" OME and blistein I have been vary happy with the set up. I've been doing quite a bit of upgrading along the way with axles drop towers in the front drop mounts in the rear new trailing arms etc....
Old Jun 22, 2008 | 08:07 PM
llesra's Avatar
ranchos are no good
pro comps are no good
ome ltrs are a waste of money because theyre not long enough
non ltr ome shocks and yellow bilsteins are good if you stay under 3"
koni shocks are good but expensive
bilstein 7100s and fox 2.0 shocks are nice but expensive
i like rovertym springs over ome springs. dont really know why.
if you lift under 3", all youll need are the springs and shocks. extended brake lines depending on shock choice. if you go over 3" youll need lots more. go to http://www.rovertym.com/ and see what theyve got and give them a call and see what he recommends.
im currently running rovertym 3" springs w/ 1" spacer, bilstein 7100 shocks, and spring retainers in the rear and im very happy with it.
Old Jun 23, 2008 | 08:56 AM
Arsell said it, follow his suggestions and as he has mentioned, there is more to a 3" the lifting it, depending on if you have a D1 or D2.
Old Jun 23, 2008 | 04:29 PM
rwarren92's Avatar
can a moderater make a stickie for landrover disco suspension lift so people wont have to keep posting "what's the best suspension lift" "or whats the best shocks"in the long run it would best for the forum
i Think it would be a
Old Jun 23, 2008 | 04:37 PM
rwarren92's Avatar
my truck tends to rock and roll alot when on bumpy paths would ome n25 n115 with rover tym 2" help that
Old Jun 24, 2008 | 08:06 AM
ORIGINAL: rwarren92
Are you talking about a D1, if so yes, either that or a full OME set of coils and HD shocks.
Buddy Lee
Mar 31, 2014 10:39 AM
stu44mag
May 20, 2009 09:09 PM
C-MAN
Mar 7, 2009 03:57 PM
C-MAN
Mar 7, 2009 09:55 AM
My98disco
Aug 2, 2005 12:33 AM
