Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Off Road set of tires
Old Apr 27, 2006 | 08:16 PM
Prepilot_3ck's Avatar
Default Off Road set of tires
I would like to buy a set of REAL off-road tires for my '03 Disco HSE. It's my daily driver so I keep a set of Toyo Proxie's on there. Helps with the milage, noise etc... However, they suck off-road. So I'd like to get a full set of wheels and tires that I can swap out when I go off-road. How big can I go without rubbing the fenders? Any brands, I found some General Tire Grabber AT2's that looked pretty good, but I'm just not sure about the size.
Thanks,
Brian
Old May 21, 2006 | 05:57 AM
TexasBadlands's Avatar
Default RE: Off Road set of tires
I have a 2002 Disco II and have been searching for OFF ROAD tires for two weeks so far and can't find crap. Ticks me off that you can't find any off road tires for a supposedly OFF ROAD vehicle! Even Land Rover North America had a stupid reply to an email I sent about it.
They sent out my Disco II with 18" wheels, and nobody makes OR tires for em!
Old May 21, 2006 | 12:24 PM
ORIGINAL: Prepilot_3ck
Thanks,
Brian
Brian,
You might consider buying a used set of factory 16" alloys off of one of the Rover forum classified sections, there are a lot of them for sale.
As for size, go to a 245/75/16 tires and I would suggest a BFG MT with teir 3 ply side walls, very strong and tons of traction.
Where do you live and what sort of wheeling do you plan on doing, what kind of ground or soil, maybe lots of mud????
Mike
Old May 21, 2006 | 12:29 PM
ORIGINAL: TexasBadlands
How much wheeling are you planning? If you plan on much, you had better plan on selling those 18" wheels and buy some 16"ers. 16" tires are much stronger then 18's, offer a greater selection and won't get torn up like the 18's off the road.
Are you planning on a lift some day, if so you should take that into consideration when buying tires.
Mike
Old May 21, 2006 | 01:35 PM
Landzu's Avatar
General Grabber AT2 comes in a 18" to fit the Disco II.
www.tirerack.com/
Old May 21, 2006 | 02:11 PM
ORIGINAL: Landzu
www.tirerack.com/
Still an 18" tire with a very vulnerable side wall. I would only do something like that if your only wheeling plans were to hit a dirt road once or twice a year, you really shouldn't do any wheeling that would require airing down for better traction.
Mike
Old May 21, 2006 | 03:13 PM
I had thought about putting just regular tires on the 18" wheels again, and buying a set of steel 16" wheels with some BFG's on em to switch out. We wheel the Rover only a couple of times a year, mostly in deep sand. However I am prone to quick and nasty sessions of deep mud running if I see some somewhere...... hehe..
Old May 21, 2006 | 04:19 PM
Landzu's Avatar
ORIGINAL: Landzu
www.tirerack.com/
They also have customer reviews of the tires.
Old May 21, 2006 | 04:52 PM
Just so you know, factory 16" alloys can be bought for less then good set of steel wheels. Either way, but 16X8" wheels designed for Rovers.
Good luck,
Mike
Old Aug 16, 2006 | 07:24 PM
kcabpilot's Avatar
There are a couple of choices for 18 inch off road tires in 285/65 R18 size. one is Nitto Tires and the other is BFG
I think you'll have to do a lift to get them to fit though.
bosshogt
Tires
Nov 23, 2009 06:54 PM
sbland0208
Aug 13, 2009 12:18 PM
blacksparrow
Tires
Feb 4, 2008 01:02 PM
millejdq
Oct 17, 2007 10:24 AM
TexasBadlands
Jun 12, 2006 07:47 PM
