Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
interco trxus mud terrains
Old May 18, 2006 | 07:35 PM
surfrover's Avatar
Default interco trxus mud terrains
hey i'm thinking about getting these tires for my disco I, does anybody know if this brand is anygood or should i just go with pro comp or bfg's?
Old May 20, 2006 | 10:44 AM
Landzu's Avatar
Default RE: interco trxus mud terrains
A friend of mine had a set of Super Swampers great off road tire.
Not for the road, the tires would follow any imperfection to the point
that it would try to yank the steering wheel from his hands.
I got to drive his truck once it was to much.
I have been very happy with my BFG ATs.
They are hard to beat for on road and off.
I have 245-75-16 's
Old May 20, 2006 | 04:47 PM
ORIGINAL: surfrover
What do you do with your truck, how much wheeling, is this your main driver?
What size tires your running, and on what, D1 or D2?
Mike
Old May 22, 2006 | 05:15 PM
surfrover's Avatar
it's a d1 with stock sized tires as of right now. i'm thinking about getting a lift and maybe 31's possibly 32's if i can get them to fit with the lift i want. i do just a little off road driving like mudding every now and then and have gotten it stuck pretty bad once, but i am looking to get a little more into it. i also do some beach driving for surfing on some trips me and my friends take. it is my main ride to work and everything like that.
check my photos out to see it the night it was stuck.
Old May 22, 2006 | 08:29 PM
Do the lift, stay with 2"s. Who are you thinking about getting?
For the price of those tires go BFG AT's or MT's and have a tire that will last forever and treat you well. What width wheel do you have, try and use 16/8 wheels if you can.
Mike
Old May 22, 2006 | 11:11 PM
surfrover's Avatar
i just ordered the old man emu lift this afternoon! i was planning on staying with those rims and everything so im definetly leaning towards the bfgs.
Old May 23, 2006 | 11:58 AM
ORIGINAL: surfrover
Did you also order a new steering stabilizer also? You should.
OME' is great, I did a 3" lift using there shocks and springs.
Mike
Old May 23, 2006 | 03:04 PM
surfrover's Avatar
yeah i got the steering dampner and the castor kit as well. which brings up another question, what the crap is a castor kit? it was part of the lift kit i ordered and i've never heard of one and i can't find anything out about it. i'm pretty confident that between me and my dad we could put everything else on but i have no idea what this castor kit is so i don't know if we could do that or not. anyways, thanks for all the help so far.
Old May 23, 2006 | 03:19 PM
ORIGINAL: surfrover
Some one got you!!!
Gastor kits are used to reset the vehicles castor angle after a tall lift has been done. With out it, on a tall lift 3Plus inches, the vehicles tends to develop a sensitive steering problem. With kit kit you ordered, you will probably will only get about a 2"lift and I doubt the kit will be necessary.
I have a 3" plus lift on my D2 and noticed a slight difference, but not enough to worry about and didn't make any castor changes.
I would call and cancel the kit or at least make sure if you get it that you can return it if you decide not to use it after the lift is done.
Mike
Old May 23, 2006 | 09:41 PM
surfrover's Avatar
dude, thanks mike. i was able to call and change my order, you just saved me like $100! i'm also a little less nervous about putting it on myself now. thanks alot man.
