1999 LR Discovery 2 - Whole truck and Parts - Strong Engine
1999 Land Rover Discovery
  • 1999 Land Rover Discovery - 1999 LR Discovery 2 - Whole truck and Parts - Strong Engine - Marmora, NJ 08223, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • 1999 Land Rover Discovery - Lots of Parts for Discovery 2 - Accessories - $1,234 - Marmora, NJ 08223, United States
    Expired
    Expired
    Expired
7th Gear
  • Price $1,234
  • Location Marmora, NJ, 08223, USA
  • VIN SALTY1245XA226012
Whole truck, parts, and accessories for sale.  Not removing parts that make the truck incomplete.  See items below with prices.  Buyer responsible for pick up or delivery costs.
1999 Land Rover Discovery II $3500
131,xxx miles
Body and interior in great shape
Runs great!
All power windows work
All-weather mats throughout
Dual climate controls
Original Owner’s Manual
Cargo Cover
Many service records and upgrades
Engine recently reconditioned and smooth!
Bad Frame and Transmission (no 4th or reverse) Replacement available
 Recently replaced parts:
Brakes Rotors (drilled and slotted)
Front Calipers
Brake lines
Rear brake caliper mounts
Oil pump
Water pump
Tie rod ends
Tail gate hinges
Engine head fully rebuilt
New coils and spark plugs
Timing Chain and Gears
Moonroofs repaired and functioning
Power steering pump
A/C compressor and system reconditioned
 Mods:
2” lift Old man emu
Steering damper
Heavy duty track rod
Heavy Duty drag link
Damper bracket mount
MagnaFlow Exhaust
Mud Tires (very little use) Firestone Destination M/T 265/75R16 - $400 for all 4
Safety Designs Safari Rack (Recently powder coated) - $900
Hella Lights (harness and switch never installed) - $200
 Extra Parts:
Leather Shift **** (automatic and NEW) -$50
Seat heater element (New) - $50
Front Shock towers - $50
Rear frame repair kit –  Rear Chassis Leg Repair kit for Land Rover Discovery 2 TD5 (powerfuluk.com) - $50
Transmission with torque converter (Grade A salvage) - $250
Lug nuts - $50
Wheel fender flare trim set - $150
Coolant lines - $20
2004 brake booster - $40
Passenger side mirror - $50
Headlight bulbs - $15
Interior Dash light bulbs $15
Passenger side rear corner trim plastic - $10
Remote keys - $10
XYZ switches – 2 – (1 unknown, 1 working but needs rivets/screws) - $40
Oil drain plug washers - $5
Transmission drain plug washers - $2
LR oil filter - $5
Extra rims with tires (90% tread)
Door Weather strip - $10
Magnaflow 1-2 exhaust tip $30
O2 Sensor - $20
Picture Title Part Category Price Part Description
Lots of Parts for Discovery 2 Accessories $1234 Mud Tires (very little use) Firestone Destination M/T 265/75R16 - $400 for all 4
 Extra Parts:
Leather Shift knob (automatic and NEW) -$50
Lug nuts - $50
Coolant lines - $20
Remote keys - $10
LR oil filter - $5
O2 Sensor - $20
Old Feb 9, 2022 | 02:24 PM
sdtimb's Avatar
PM sent.
Old Feb 16, 2022 | 08:39 AM
greenroomvision's Avatar
7th Gear
UPDATE
1999 Land Rover Discovery II $2800
131,xxx miles
Runs great!
Cargo Cover
Front Calipers
Brake lines
Oil pump
Water pump
Tie rod ends
Tail gate hinges
Power steering pump
Mods:
2” lift Old man emu
Steering damper
MagnaFlow Exhaust
**** Additional parts will be listed individually *************
Old Mar 13, 2022 | 06:55 PM
sdtimb's Avatar
Received and installed the seat heater element. Works great. Thanks!
Old Oct 13, 2022 | 07:37 PM
Johnyakimo1855's Avatar
Default Wheel Well Trim or Flares
If you still have the set is it new? What is manufacturer? Im interested
Old Oct 17, 2022 | 09:29 AM
losinov's Avatar
PM sent last week.
Old Oct 17, 2022 | 04:25 PM
timsrover's Avatar
How much for the steering wheel?
Old Oct 21, 2022 | 04:20 PM
disco96sd's Avatar
do you have the center console master power window switch control available ? part on left - don't need switches
Old Jan 1, 2023 | 11:44 AM
danbrown100's Avatar
Hi,
I am looking for a new XYZ switch. Just wondering if you can sell me your 2? What color is the plastic on the housing (tan or black?)
Thanks
Dan
Old Mar 16, 2023 | 03:47 PM
eta98D1's Avatar
4wd High
Willing to part with mats?
