2001 Discovery 2 SE - Modified
2001 Land Rover Discovery
  • 2001 Land Rover Discovery - 2001 Discovery 2 SE - Modified - Used - VIN SALTY12481A702020 - 119,500 Miles - 8 cyl - 4WD - Automatic - SUV - Red - Beaver, PA 15009, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $13,999
    • OBO
  • Location Beaver, PA, 15009, USA
  • Condition Used
  • VIN SALTY12481A702020
  • Mileage 119,500
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Red
This 2001 Land Rover Discovery II SE is finished in Alveston Red over tan leather and is powered by a 4.0-liter V8 mated to a four-speed automatic transmission and a dual-range transfer case. Equipment includes Terrafirma shocks and springs, 16 inch Terrafirma wheels, steel front and rear bumpers, a Smittybilt XRC winch, roof rails, safari windows, a rearview camera, TuffRok halo-ring headlights, dual-zone automatic climate control, and an aftermarket Alpine stereo. Work performed during current ownership reportedly consisted of repainting the roof, replacing a portion of the frame, servicing the braking and cooling systems, resurfacing the cylinder heads, and changing the head gaskets, spark plugs, coil packs, and driver’s door window motor. This Discovery II has 119k miles and is offered with a clear Pennsylvania title.
The 4.0-liter V8 produced 188 horsepower and 250 lb-ft of torque when new. Service during current ownership reportedly consisted of resurfacing the cylinder heads and replacing the following components:
Cylinder head gaskets
Fuel injectors
Radiator and hoses
Radiator fan and fan clutch
Water pump
Thermostat
Fuel pump
Spark plugs and plug wires
Ignition coils
Serpentine belt and pulleys
The cabin features tan leather upholstery on the power-adjustable front seats, while woodgrain trim accents the dashboard and door panels. Amenities include dual-zone automatic climate control, cruise control, safari windows, dual sunroofs, and an aftermarket Alpine stereo connected to a pair of SWS subwoofers integrated into the swing-out rear door. The headliner has been replaced with a spray-on liner, and the driver’s side window motor is a replacement. The courtesy lights do not work when the doors are opened, the power window switch surround is loose, and a passenger side sun visor clip is broken. The heater fan motor has been cleaned out and minor wear throughout the interior is depicted in the gallery.
A two-tone leather-wrapped steering wheel frames a 135-mph speedometer, a 6k-rpm tachometer, and fuel and temperature gauges. An aftermarket multifunction display for auxiliary read-outs is affixed to the windshield. The digital odometer indicates 119+k miles.   The setup mode for the Alpine stereo is controlled via a dash-mounted auxiliary button.
The Carfax report shows the car was declared a total loss by an insurance company in April 2012 and lists history in Virginia, Washington D.C., Maryland, and Pennsylvania.  Though the title does NOT show as rebuilt nor salvage.   The title is clear and clean.
Bunch more pictures can be found on my website: Here
