2002 P38 Range Rover HSE | Engine Issues
2002 Land Rover Range Rover
  • 2002 Land Rover Range Rover - 2002 P38 Range Rover HSE | Engine Issues - Used - VIN SALPM16472A466047 - 160,000 Miles - 8 cyl - 4WD - Automatic - SUV - White - Austin, TX 78756, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    $1,500
    • OBO
  • Location Austin, TX, 78756, USA
  • Condition Used
  • VIN SALPM16472A466047
  • Mileage 160,000
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color White
Up for sale is my beloved 2002 Range Rover, aka “Remy”, in the final year model of the 2nd generation.
NOTE: Sadly it is currently suffering from some engine misfiring, but technically runs. It just had a recent service to try to remedy it - installed 8 new fuel injectors, new spark plugs, new ignition coils, and new ignition wires, but no luck..
If anyone wants to try their luck, it’s still a beautiful car to own and is a beast off-road, as it’s the only other SUV other than Jeeps to have solid axles front & rear. Off-roading was an occasional hobby, but mostly was a daily driver.
The other major issue is cosmetic, and happened while off-roading and hit a large rock on the front right corner, destroying the foglight, some of the bumper, the windshield washer reservoir, bent the frame a little, and threw off the steering wheel alignment (but still drives straight)
One other issue is that there was a coolant leak in the heater core, and was cheaper to remove instead of replace (no heat)
Major issues:
- Engine misfiring
- Front right bumper
Things that don’t work:
- Cruise control
- Heat
- Navigation
Things that work great:
- A/C, very cold
- CD Player, all 6 discs work
- Tape player
- Heated seats
- Engine coolant system
- Brakes, recent new rotors & pads, excellent
- Low-range transfer case
- Power seats
- Sunroof
- All lights inside & out
Off-road Upgrades:
- Ashcroft limited slip differentials for both front & rear axles (amazing)
- RTE Heavy duty coil springs for 2” suspension lift
- TerraFirma long-travel off-road shocks
- TerraFirma steering damper
- Not included, but, I used a set of 265/75 tires on Discovery 16" wheels for off-roading
Facts:
Year: 2002
Miles: 160k
Color: Chawton White
Engine: 4.6L Rover V8 w/ Bosch management
Tires: Cooper Discoverer ATP 265/65R18
I also have multiple service records, and a lot of the major parts have been replaced over the years - water pump, thermostat, belts, and many more
Thanks!
