2007 LR3 SE w/ extras!
2007 Land Rover LR3
  • 2007 Land Rover LR3 - 2007 LR3 SE w/ extras! - Used - VIN SALAE25497A436467 - 8 cyl - 4WD - Automatic - SUV - Black - Little Rock, AR 72207, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    Sold
    $7,000
  • Location Little Rock, AR, 72207, USA
  • Condition Used
  • VIN SALAE25497A436467
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Black
New vehicle on order, so time to sell this great Rover!  Currently in Texas, but will be "home" in Little Rock, AR, and available for its new owner in the first week of July.
Black with tan leather interior, 3rd row seats, rear air.
Mileage - 118,000
$7000 (firm)
Located in Little Rock, AR
Two owners.  Good to very good cosmetic and functional condition.  Runs great as a daily driver with no active problems. Sunroof and all power windows.  Air suspension and off-road settings all perfectly functional.  Engine starts and runs great!  Solid on highway, and rarely taken off road.
Current road tires, but if my extra set of wheels with BFG off road tires (also listed here on Land Rover forum marketplace) don't sell separately, then they will be included in the sale of this vehicle for an discounted price if interested.
Land Rover rubber floor mats, Rear space rubber mat and Dog guard/ cargo partition installed.
 A lot of great life left in this vehicle which has been cared for impeccably. See extensive service history below.  Significant systems prone to failure in these vehicles have already been addressed and replaced! Most was covered by an extended warranty and done at local Land Rover dealership!
 Tires have about 30K miles but still a lot of functional tread left.
A few cosmetic blemishes as any >100K car will have, but nothing major.  Parking sensors fault out and I just turn them off since I don’t really need them.  Probably just needs one or two replaced.  Heat and air work great, starts and runs perfectly.
Vehicle Repair and Modification History
Purchased 3/18/2014 with 67,000 miles
        Service Records from Previous owner
 0-40K - regular oil changes/routine maintenance at dealership
43069 11/14/11 -BG Injection Service (carbon build-up on injectors)
                         -45K service
                         -replaced both fuel sensors & fuel tank seal (was reading empty when full
                         -Airbag on dash cracking - replaced upper dash panel
43127 11/16/11 -sunroof not working - replaced sunroof assembly
46786 4/10/12  -Gas flap broken - replaced
                        -Poor acceleration from cold start - BG injection service
                        -Fuel gauge not accurate - replaced both fuel sensors
50933 8/23/12 -check engine fault - coolant temp sensor replaced
53437 11/14/12 -suspension fault - compressor replaced
53745 11/30/12 -check engine light - replaced thermostat
53K-67K -serviced at private garage (no problems, no records)
                        -Hood replaced & painted due to dent from fallen branch
                                                      Vehicle transferred ownership (picked up in Memphis)
67659 3/28/14 -added front aux input and amplifier (passive) to stereo
            4/14 -Dog guard and rubber matts added
                        -replaced front brakes (rotors/pads) & alternator
                        -replaced front control arms & bushings
                        -replaced hood struts & tightened upper tailgate posts
68000 5/1/14 -Oil and filter change, cabin and engine air filter
                     -Rear differential replaced & complete fuel tank replaced withnext generation fuel tank.  Transmission pan replaced
70000 7/20/14 -L front wheel bearing/hub assembly replaced
73800 -Oil/Filter change and dealer fixed “DMTL” valve and gasket & replaced #8 ignition coil
77577 - -Oil/Filter change @ dealer - inspected belts - no problems
77800 - -replaced both sun visors and L A-Pillar trim due to peeling fabric
                        -new windshield due to crack (original Land Rover)
82569 5/29/15 -Oil/Filter change, recharged AC coolant, four wheel alignment
84271 7/10/15 -Replaced R front wheel hub and bearing
​​​​​​​                         -Replaced L rear wheel bearing
84682 7/22/15 -L rear wheel bearing had to be re-done due to improper installation (above)
87417 9/17/15 -L rear axle assembly replaced (discovered during above service to have a lube leak)
89000 2/26/16 -Oil and Filter change
91361 7/20/16 -Oil and Filter change, rear brake pads and rotors, front end alignment & centered steering wheel
98000 5/2017 -Oil and filter change
99000 10/2017 -front brake rotors and pads replaced
100000 2/2018 -driver’s side air strut replaced (was leaking air)
​​​​​​​                         -replaced thermostat housing - leaking coolant
​​​​​​​                         -replaced all drive belts and spark plugs - British Unlimited
9/2018 -purchased two new key fobs and had programmed
105000 12/2018 -rear brake pads, Oil/Filter change, cabin & engine air filters, front and rear wiper blades.  New battery
6/2019 -R front air strut replaced
112000 1/2/20 -Oil and filter change - front and rear wiper blades
116500 12/27/20 -Oil and filter change - front and rear brake pads (rotors good) front and rear wiper blades
 VIN Decoder Spec Sheet
 Interior Trim Combinations - Alpaca Leather Sts Ebony Black/Alpaca [TCE]; Paint Colours - Java Black [697]; Exterior Lighting Packs - Bright Pack NAS [017AG]; Impact Criteria - NAS (HIC) [026BV]; Sunroof - electric Sun Roof [019AG]; Shift Interlock - Shift Interlock [166SF]; Fuse Labels - Fuse Label [156AA]; Literature Packs - NAS Literature Pack [002BQ]; VIN prefix position 11 - VIN prefix position 11 - A [146AA]; Disc Brakes - "18"" Front & Rear Vented & Dirtshields" [020AV]; CD Holders - CD Holder - Console [088EI]; Lighting Pack - Lighting Pack [074HJ]; Temperature Control - Hevac Controls USA [022BE]; ICE Remote Controls - Remote ICE controls [025CK]; Home Link - Home Link [025EB]; CD Player - Integrated MOST 6 CD [025GK]; VIN prefix positions 1-3 - VIN prefix positions 1-3 - SAL [138AA]; Exhaust Muffler - NAS Exhaust Muffler [076AA]; Paint Bands - Micatallic Paint [024BB]; In Car Entertainment / Speakers - Hi ICE Branded [025GP]; Rear Seat Configuration - 35/30/35 Seat Split [033DR]; Seat Lumbar Adjustment - Lumbar Adjustment-Electric Driver Only [033GK]; Steering Column - Manual Tilt & Reach Adj Steering Column [049AK]; Modular Front End - Modular Front Panel & Front End Module [099AJ]; Body Types - 4 Door Estate [099AB]; Steel / Alloy Options - Alloy 8x18 Style 2 255/60 R18 AT [029JN]; Number Plate Plinth - Front Number Plate Plinth NAS [056AS]; Loadspace Nets - Loadspace Mouldings [026FB]; Beam Pattern - Beam Pattern NAS [064DL]; Radiator Undertrays - Radiator Undertray [093AG]; Tyre Labels/Instructions - Tyre Data Label N.A.S. [057BH]; Suspension - Front & Rear Air Suspension (4Cas) [027BY]; Cruise Control - Manual Cruise Control [065AE]; Glass - Privacy Glass Dark Tinted [047AB]; Interior Trim Finish - TPO Trim Finish [088CV]; Switch - Hazard Warning - Hazard warning Switch [088CR]; Master Lights Switch - Master Light Switch [088CQ]; Battery Isolation Switch - battery isolation switch [021AN]; Console Auxilliary Power Socket - Auxiliary Power Socket [054AC]; Cup Holders Row 3 - Cup Holders (2) Row 3 [088CG]; Cup Holders Row 2 - Cup Holders (2) Row 2 [088CE]; Cup Holders Row 1 - Cup Holders (2) Row 1 [088CC]; Message Centre - Message Centre [087AE]; Rear Lamp Clusters - Rear Lamp - Side Marker [064DP]; Park Distance Control Sensor Rear - Park Distance Control Sensor Rear [086EH]; Wheel & Tyre Configurations - Tyres Goodyear [029CJ]; Interior Contrast Colours - Alpaca Contrast Parts [080BT]; Tunnel Console - Alpaca Tunnel Console [080BP]; Interior Colourways / Environment - Ebony Black Interior Environment [080BK]; Roof Finishers - Roof Finisher-Black [080BH]; Transmission - Automatic 6 Speed w. Steptronic [078BO]; Bonnet Lock - Bonnet Lock [076EB]; Locking Radio Frequency - 315 MHZ frequency [076DG]; Perimetric Protection - Perimetric Protection [076DA]; Horn Types - Twin Tone Horn [076CW]; Product Name Badges - Rear - LR 3 Badges [057CX]; Wheel Arch Liners - Wheel Arch Liner [023AN]; Rear Door Child Proof Locks - Manual Child Safety Latch [070AO]; Plinths Rear Number Plate - Number Plate Plinth - NAS [056BA]; Exterior Mirrors - Drvr Flat/ Pass Convex Mirrors [031BA]; Light Sensing Headlights - Automatic Low Light Sensing Headlights [064CY]; Fuel Type/Rating - Lead free petrol [103AH]; Headlamp Cleaners - Headlamp power wash [064BV]; Headlamp Leveling - Dynamic Headlamp leveling [064BR]; Puddle Lamps - Puddle Lamps - Front and Rear [064BN]; Front Foglamps - front fog lamps [064AP]; Loadspace Covering - Loadspace Cover [063AH]; Jacks - Scissor Jack [060AU]; Steering Wheel Styles - Leather Steering Wheel [032BV]; Decals - Colour - Brunel Decals [057CL]; Derivative Badges - Badge SE [057BW]; Battery - H7 Battery [021BB]; Equipment Stowage - Standard Tools & Jack [056BF]; Spare Wheel - Underfloor - Spare Wheel Steel Reduced Section [029IS]; Tyre Pressure Monitor - Tyre Pressure Monitor 315MHZ [062AC]; Twin Sun Visor - Twin Sunvisors Vanity Mirrors Illuminate [031CE]; Armrest (Front Seat) - Front Armrests [033EW]; Smokers Pack - Smokers Pack [094AA]; Steering Aids - Power Assisted Steering [049AA]; Handbrake - Electronic Park Brake [043AS]; Console Mounted Switches - Terrain Optimisation Switch [088CP]; Electrical harness - NAS Harness [030BX]; L319 Trim Packs - Discovery V8 SE [350CD]; Rear Wash Wipe - Tail Door Wash Wipe [040AP]; Cigar Lighter - Cigar Lighter and Front Ashtray [088CJ]; Heated Rear Windscreen - Heated Rear Windscreen [040AI]; Passenger Airbag Disablement Sensors - Passenger Airbag Disablement NAS(OCS) [030DA]; Facia Switches - Facia Dimmer Illumination [038AX]; Front Seat Adjustment - Electric Front Seat Adjust Non Memory [033GU]; Power Unit Series - 4.4 V8 AJ Petrol [200AC]; Land Rover Model Year Indicators - Land Rover 2007 Model Year [001BH]; Grab Handles - Cantrail Mounted - 5 Passenger Grab Handles [042AN]; Locking Fuel Filler Cap - Fuel Filler Flap - Non Central Locking [053BJ]; Roof Racks - Roof Rails [060AD]; Emission Directives - ULEV2 [053BS]; Seat Material - Leather Seats [033AS]; Instrument Packs - MPH/KPH Speedometer - NAS [038BH]; Interior Mirrors - Electro Chromic Interior Mirror [031CG]; Air Con Rear - Rear Air Conditioning [022AZ]; Map Reading Lamps - Dome & Map Lamps [030CZ]; Rear Seat Belts - Rear Seat Belts ALR [026FA]; Electric Door Mirrors - Elec Htd Adj Door Mrrs [031AX]; Pull Out Tray - Pull Out Tray & Cup Holder [088CH]; Loadspace Lamp - Loadspace Lamp [030CY]; Glovebox Lamp - Glovebox Lamp [030CX]; Roof Lights - Fixed Rear Roof Light [030CT]; Footwell Lighting - Footwell Lighting [030CV]; Instrument Display Language - US/English [038BW]; Seat Configuration - Seven Seats [033BI]; Rain Sensor - Front Rain Sensor - Windscreen Mounted [030CQ]; Air Conditioning - ATC Air Conditioning [022AX]; Air Bag Sensors - Air Bag Sensor [026EX]; VIN prefix position 10 - Vin prefix postion 10 - 7 [145AM]; Audible Seat Belt Warning - Audible Seat Belt Warning [026AL]; Front Seat Belts - Inertia Front seat Belts-ALR [026BM]; Anti Lock Brake Types - A.B.S + Traction Control [020AK]; Rear Axle Differential - Rear Axle Open Diff [027CB]; Front Differential - Front Axle Open Diff [027CA]; Stability Control System - Integrated Vehicle Dyamics [027BZ]; Drive Hands - LHD [252SF]; NAS VIN (when EEC & NAS prefix required) - SALLAAA547A [148EA]; VIN format type - VIN format - NAS [147AB]; VIN prefix position 9 - VIN prefix position 9 - ? (check digit) [144BC]; VIN prefix position 8 - VIN prefix position 8 - 4 [143AY]; VIN prefix position 7 - VIN prefix position 7 - 5 [142AP]; VIN prefix position 6 - VIN prefix position 6 - 2 [141AY]; VIN prefix position 5 - VIN prefix position 5 - E [140AC]; VIN prefix position 4 - VIN prefix position 4 - A [139AK]; Provision for Luggage Retention - Luggage Net [135AA]; On-Board Diagnostics - OBD II System [125AM]; Carpet Colours - Alpaca Beige Carpet [124AE]; Gear ***** - Leather covered gear **** [117AA]; Weight Plates - 7121lbs USA/Canada/Mexico [097BA]; Scripts / Labels - NAS Script [096SO]; Terrtorial Labels - USA Labels [096BE]; Air Bag Labels - NAS Air Bag Labels [096AK]; Headlamps - Xenon Headlamps (NAS) [064CS]; Park Distance Control Sensor Front - Park Distance Control Sensor Front [086EG]; NAS Telephone Frequency - NAS Phone Frequency [025KA]; Digital Radio Receiver - SDARS (Sat Dig Aud Receiver System) NAS [025JA]; Voice Input System - Voice Input / Recognition System [025EZ]; Hands Free Telephone Preparation - Personal Telephone Integration [025DY]
Old May 15, 2021 | 07:28 AM
ejwhitson's Avatar
3rd Gear
Definitely interested. Would love to see more photos when you get a chance!
Old May 17, 2021 | 11:14 AM
drcoop's Avatar
Will do. Thanks for your interest!
