2010 Range Rover 5.0SC (L322) - Engine Replaced & Timing Chains Done
2010 Land Rover Range Rover
  • 2010 Land Rover Range Rover - 2010 Range Rover 5.0SC (L322) - Engine Replaced & Timing Chains Done - Used - VIN SALMF1E48AA312654 - 202,932 Miles - 8 cyl - 4WD - Automatic - SUV - White - Crozet, VA 22932, United States
    Expired
    $11,000
    • OBO
  • Location Crozet, VA, 22932, USA
  • Condition Used
  • VIN SALMF1E48AA312654
  • Mileage 202,932
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color White
Price: $11,000 obo
Mileage: 202,932 (Chassis) / ~18,000 miles since engine replacement
Color: Alaska White Exterior / Arabica & Ivory Interior
Photo Album: https://photos.app.goo.gl/YJNq3WKvNBYW8twt6
I am selling my 2010 Range Rover Supercharged (L322). While the chassis currently shows 202,932 miles, this truck has undergone a massive amount of mechanical restoration under my ownership and the previous owner's.
 I have extensive documentation and receipts for parts and labor which will be provided to the buyer. This is a well-sorted driver for an enthusiast who understands the value of maintenance up to date.
Engine & Drivetrain Highlights:
• Engine Replacement: The 5.0L SC motor was replaced by the previous owner in November 2022 (approx. 185k chassis miles).
• Timing Chains: Addressed during the engine replacement in 2022. (Note: Documentation also shows timing chains/guides were previously done on the original engine at 137k miles in 2018, proving this truck has always been maintained).
• Transmission Service: ZF 6HP service completed in March 2024, including sonnax zip kit, new fluid, pan/filter, mechatronic sealing sleeve, and shift solenoids,.
Exhaust:
• Catalytic Converters: Replaced with MagnaFlow direct-fit converters in July 2024.
• Luxman stainless silencers/mufflers
• Cooling System Overhaul (Jan 2025 - ~$4,200 Service): Work included the rear coolant crossover pipe (heater manifold), water pump, thermostat assembly, oil cooler tube seals, and supercharger removal/reseal with new intake manifold gaskets,,,.
• Ignition & Fuel System:
    ◦ New Bosch Fuel Injector Kit and PCV Valve Kit (April 2024).
    ◦ 8 New Bosch Direct Ignition Coils and Spark Plugs (April 2024),.
    ◦ New Mass Air Flow Sensor (June 2024).
    ◦ New Bosch Oxygen Sensors (Aug 2024),.
• Suspension Refresh:
    ◦ Rear Air Suspension Hose repair (July 2024),
    ◦ Air Compressor (July 2024),
    ◦ Front & Rear air blocks (July 2024)
• Braking:
    ◦ Zimmermann Z-Coat Rotors and Jurid Pads installed March 2024,.
Upgrades & Interior:
• Infotainment: Upgraded to a 10.25" Android 12.0 Infotainment system (w/ 8GB RAM), modernizing the cabin while retaining factory look.
• Towing: Trailer wiring kit installed.
• Interior: Arabica/Ivory leather treated with correct dye for refurbishment.
• Exterior: Paint treated with Icon Rocklear and underbody oil undercoated by Deep Reflections detailing in 2024.
Included Parts:
    ◦ Bilstein Front Struts/Shocks
    ◦ New Control Arms, Tie Rod Ends, and Sway Bar Links
    ◦ Front right headlight to address fogging light
    ◦ Surround cameras for driver side mirror and front bumper
    ◦ Original headunit
    ◦ New front right headlight to address fogging lense
Condition: The vehicle is in Alaska White with the Arabica/Ivory interior. It has been a Virginia car for some time. Given the mileage, there is expected wear, but the mechanical investment speaks for itself.
I have a folder of receipts including the engine invoice, the recent cooling system invoice from British Precision Service, and parts receipts for all the work listed above.
 Please contact me with any questions or to arrange a viewing:
doug.carton@gmail.com
661-839-6685
