2011 Land Rover LR4 HSE $15000
For Sale2011 Land Rover LR4
Located in Ballwin Missouri (St. Louis area).
For sale. Fully maintained and in excellent condition. Used as daily driver and on some longer dirt road overland trips to MT, WY, CO, and other places. Never off-roaded “hard”.
- Impanema Sand color with tan interior.
- Melville & Moon seat covers (leather is fine underneath)
- GOBI Stealth full rack with removable sunroof panel, awning brackets and rear ladder.
- TuffAnt 18” Steel Wheels (5)
- Cooper Rugged Trail AT tires
- IDCore Bluetooth CarPlay and Android auto installed.
- Leather seats are the LUX Windsor style.
- H8 AGM battery (biggest that fits)
- Console fridge from RR Sport added.
- LR headlamp and tail light guards.
- GAP IID tool included.
- Full LR pdf service manual included.
Front passenger headlamp cover broken. These can be DIY replaced with a part from Powerful UK.- Some hood chips and
very light pinstripes(invisible when waxed) - Some bumper scuffs from parking lots
94,327 11/24/2020 $5247
- Exhaust Manifolds
- Front Lower Control Arms
- Alignment
- Serpentine Belt
- Oil change Mobil1 EP 5/20
- BG Engine Performance Restorer
- BG 44K Fuel System Cleaner
- Tires Rotated
- Front differential Fluid replaced
- Transfer case fluid replaced
- Wiper Blades
- Valve Covers replaced
- Coolant Expansion Tank Hose replaced
- Degrease Engine
- Right CV Axle replaced
- Parking Brake Module replaced with cables
- rear brakes replaced
- Oil Change Mobil1 Extended Performance 5/20
- Engine Air Filters
- Wiper Blades
- Spark Plugs replaced NGK ILKAR7C10
- Coolant reservoir cap replaced
- Front brake wear sensor replaced
- Tire Rotation
- Complete new rear brakes and sensor.
- Brake Fluid flush
- Front brakes replaced
- Bonnet Switch Replaced
- air filters LR011593
- Cleaned MAF sensors
- New H8 AGM Battery
- Bosch Wipers
- Oil Change Mobil1 EP 5/20
- Replaced rear lift gate actuator
- Heat Manifold Tube Replaced
- Brake Lines Replaced
- Brake Fluid Flush
- Cabin Air Filter Replaced
- Front Differential Fluid Change
- Rear Differential Fluid Change
- Transfer Box Fluid Change
- Oil & Filter change
- Engine Air filters replaced
- EAS Tank Replaced
- Inspection
- Intake Manifold Gaskets LR010881
- Water Pipe Assy Front LR018275
- Bleed Plug LR011038
- Throttle Body Gasket LR011999
- Coolant
- Serpentine Belt
- Fan Belt
- Water Pump
- Coolant
- Replaced Transmission, pan, skid plate (?), fluids
- Oil & Filter
- New 255/55R19 Toyo Open Country Q/T 111V XL tires
- Battery Monitoring Sensor LR048601
- Fuse Holder
- Alternator LR091107
- Brake Pad Wear Sensor front
- Brake Pads front
- Brake Rotors and Pads rear
- Brake Pad Wear Sensor rear
- Oil & Filter
- Transmission Drain & Refill
- Tire Rotation
- Front Brakes Rotors and Pads
- L Front Brake Sensor
- Oil & Filter
- Leak Detection Pump
- Oil & Filter
- Oil & Filter
- Oil & Filter
- Tire Rotation
- Control Arms Replaced (front?)
- Alignment
- Oil & Filter
- Battery Replaced
- Oil & Filter
- BG203 Fuel Injector Cleaner
- Cabin Air Filter LR023977
- Engine Air Filter LR011593
- Oil & Filter
- Cabin Filter
- Fuel Injector Cleaner
- Oil & Filter
- Cabin Air Filter
- Oil & Filter
- Oil & Filter
