2011 LR4 HSE Lux 81K miles, Prospeed rack, ARB bumper
For Sale2011 Land Rover LR4
011 Land Rover LR4 HSE
LUX with only 81K miles. This vehicle is in excellent condition inside and out.
It has been dead reliable for me. All listed "repairs' were done by me
purely as preventative maintenance as I intended to keep this forever and was
trying to build a machine that I could take deep into mountains and be
confident I was going to make it back home, but plans change. When I bought
this vehicle is was bone stock so all modifications you see were done by me. I
am happy to answer any questions you might have.
Clean Utah title in hand
Willing to work with out
of state buyers and can help arrange / facilitate shipping.
Specs:
- ARB summit bumper paint matched (just installed 2 months ago)
- Just did a full paint correction and professional ceramic coating
- Stedi Driving lights, fog lights with DRL
- Prospeed roof rack with floor and cross bars (these are impossible to buy right now I waited over a year for this one!)
- Prospeed ladder
- OEM tail light covers
- 15mm lift
- 4 Corner air suspension
- 7716 lbs towing capicaty
- Slightly oversized tires with matching full size spare toyo at3 225/60/19 approximately 90% tread left
- Sound deadening added to all 4 doors and tail gate
- Paint protection film on the hood strip, headlights, driving lights, and fender corners
- Curt hitch with Factory 4 pin, 7 pin trailer wiring
- Lux Package: Upgraded leather, passive keyless entry, center arm rest refrigerator, seat memory, homelink mirror
- Rear seat entertainment with DVD changer and remote
- Heated seats, Steering wheel, windshield
- Center middle seat has been removed, but is included. It takes about 10 minutes to intall / remove
Recent Maintenance:
Everything listed has been performed within the last 10,00 miles. - Timing chain tensioners and guide rails replaced using all OEM parts!
- Water pump, thermostat, rear coolant cross over pipe, front manifold pipes, mechanical fan clutch replaced using all OEM parts
- Updated AMK air suspension compressor installed along with corresponding software update
- Other various plastic cooling connections replaced
- Spark plugs replaced
- Alternator replaced
- Front diff, transmission, transfer case, rear diff oil changed
- Power steering flushed
- New interstate battery
- Front main seal replaced
- Vacuum pump rebuilt
- Front brake pads and rotors replaced
- Both lower control arms replaced alignment
- Intake valves cleaned / walnut blasted
- air filter, cabin filter replaced
- Oil just changed
