2013 range rover superchargered
2013 Land Rover Range Rover Sport
  • 2013 Land Rover Range Rover Sport - 2013 range rover superchargered - Used - VIN SALSH2E44DA781798 - 133,000 Miles - 8 cyl - 4WD - Automatic - SUV - Black - Holly, MI 48442, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $4,500
    • OBO
  • Location Holly, MI, 48442, USA
  • Condition Used
  • VIN SALSH2E44DA781798
  • Mileage 133,000
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Black
FOR SALE - 2013 Land Rover Range Rover Sport Supercharged
No trades please.
510 HP Supercharged 5.0L V8 Automatic 4WD. Runs and drive great! Very fast! Brought up from Texas in 2022. Very clean frame and underbody with no rust. Only driven occationally in snow one season. 133K miles. 10K miles since engine has had a completed upper end rebuild with all new components.
No worries about the common timing chain issue! It’s all been replaced including 4 new OEM cam phasers, rebuilt cylinder heads, hoses, water pump, etc. New battery, brakes, electronic parking brake module, good tires
This vehicle is currently a reliable daily driver but could be taken to the next level as a fun project.
Pros: Loaded with nice features including heated seats and steering wheel, automatic HVAC, Power and memory seats, Electric console 4 can cooler, Active Suspension, Terrain and off road capabilities including ride height adjustment, Automatic 4WD transfer case, Automatic folding mirrors, Keyless Entry, Bose sounds system, Rhino roof rack, Brembo brakes, trailer hitch ( tows 7700 lbs.)
Cons: Power lift tailgate doesn’t work and must be opened manually. Slow fluid leak in the active suspension system for the anti-sway control.  Suspension System has occasional warning on dash but system works fine. Random misfire code on startup sets (I think it's due to older catalytic converters) and does not affect engine performance.  Clean Green Title. Priced well below market value for quick sale.
Located in Rose Center Township south of Holly, Michigan
