__ Series I/II/IIA/III Headlight Buckets, Mounting Hardware, and H4-Style Headlights
For SaleLights
Series II/IIA/III headlight assemblies. Includes buckets, gaskets, mounting rings with adjuster springs, European headlight lenses with H4 bulbs. These were working when removed (yesterday) from a Series III. These are the European style lenses that use a replaceable H4 bulb, as opposed to typical US spec sealed beams that get replaced as a single bulb and lens assembly. Use these to convert to Euro type. The brown on the back of the lenses is just from 50 years of living inside a Land Rover wing.
From interchange manual--
DA3208 / DA3208LUCAS, Replacement steel bowls for standard 7" headlight mountings, Land Rover Defender 90: All models up to 2016, standard 7" headli, Land Rover Defender 110: All models up to 2016, standard 7" headl, Range Rover Classic, standard 7" headlights, Land Rover Series: All models up to 2016, standard 7" headlights, Steel Head Lamp Bowl Kit for Series I, Series II, Series III,, Defender Ninety, Defender One Ten, Range Rover Classic, Defender 90, Defender 110, kit with 2 bowls, complete vehicle set, Steel Head Lamp Bowl Kit for Series I, Series II, Series III, Steel Head Lamp Bowl Kit for Defender Ninety, Defender One Ten, Steel Head Lamp Bowl Kit for Range Rover Classic
See detailed pics above. I'm a quick shipper, and will send shipping/tracking details when item goes out. Please message me if interested.
FREE 48 STATE SHIPPING. If you're in #49, 50, or elsewhere let me know and I can get you a shipping quote.
