Black Aluminium Skid Plate (Aftermarket - Easy-Fit) for Land Rover Defender L663
Accessories
  • Accessories - Black Aluminium Skid Plate (Aftermarket - Easy-Fit) for Land Rover Defender L663 - New - 2020 to 2024 Land Rover Defender 110 - Seattle, WA 98101, United States
    Expired
    $349
    • OBO
  • Location Seattle, WA, 98101, USA
  • Condition New
  • Compatibility
Make Model Year
Land Rover Defender 110 2020 - 2024
Selling unused aftermarket front undershield / tow eye cover for the 'New' Land Rover Defender L663.
This is an easy-fit design which utilizes the existing cross member rather than having to remove the front bumper and replace it like you do with the Land Rover version. I installed the same version on my Defender. I had to cut a bit of one of the washers for it to fit, but otherwise an easy install.
The specially designed brackets clamp onto the cross member to give the extra mounting point you need for the metal cover.
The great benefit of fitting this undershield is that is has 'always ready' access to the front towing eye - so you don't need to fiddle around unscrewing fixings and removing the standard plastic tow eye cover in a time of need!
This undershield will also give you some additional protection to the underside of your vehicle when off-roading as it acts as a front "skid plate".
You will received all of the brackets and fixings you need to complete this project.
