Clean 2012 LR4 HSE
For Sale2012 Land Rover LR4
Clean, meticulously maintained 2012 Land Rover LR4 HSE finished in Santorini Black Metallic and Ebony leather interior. Always garaged. Runs and drives perfectly. Air suspension is perfect. Paint is in great shape.
HIGHLIGHTS:
- Mileage: 106,800 mostly highway miles
- 5.0-liter V8, rated at 375HP / 375lb-ft torque
- HSE Package, 7-seats
- Adjustable air suspension
- Upgraded 825W, 17 speakers Harmon Kardon Logic7 sound system
- Upgraded center console refrigerated cooler box
- Rubber floor and cargo mats
- Tow package – installed wiring harness and additional trailer brake control module
- Includes original owner’s manual, 2 keys, rear cargo cover, original parts (taillights, front grille, side vents), wheel locks, and all service records since acquiring vehicle as second owner
- Florida vehicle
- No accidents
- Acquired vehicle from first owner on 6/5/2019 with 76,980 mileage
- Title in hand
- CARFAX
- Replaced original silver front grille and side vents with OEM Land Rover Santorini Black front grille and side vents to match the vehicle
- New engine start/stop button
- Replaced original taillights with LR4 MY ’14-’16 style blackout taillights with LED lightbulb for reverse light
- Replaced front headlight/fog light halogen bulbs with LED bulbs
- Replaced original side marker turn signal lights with smoke LED directional lights
- Replaced all interior light bulbs with LED bulbs
- Installed ceramic tints on front door windows only
- Regular oil changes with full synthetic oil
- June 2019 (78,225 miles) – replaced front passenger control arm
- February 2020 (82,536 miles) – replaced trunk lock actuator
- August 2020 – installed new battery
- February 2022 (94,452 miles) – replaced air suspension compressor/relay, replaced coolant crossover pipe outlet/tubes, replaced accessory drive belt and cooling fan belt
- October 2022 (99,261 miles) – fuel tank flange recall performed
- April 2023 (101,513 miles) – installed all new tires, TPMS kit, and alignment
- April 2023 (102,000 miles) – installed new front and rear brake rotors, brake pads, and wear sensors
- June 2023 (102,521 miles) – replaced left valve cover assembly, replaced brake vacuum pump seal, flushed brake system, flushed power steering fluid
- December 2023 (106,693 miles) – replaced front brake rotors (under warranty)
- PDF of complete Service Records
- Approximately 1” dent on driver side front hood
- Some stone chips, minor scratches throughout exterior
- Minor scuff on front passenger rim
- Creases on driver and front passenger seats
- Driver side door seal partially worn
- Minor separation in headliner along third row sunroof corners and D-pillar
