Defender, RRC & Discovery Parts
For SaleMiscellaneous
$130 - New OEM Front Stub Axle - FTC3154 - Fits: Defender 87 - 06 - Disco 1 89 - 98 - RRC 92 - 94
$50 each - New Terrafirma +50mm Stainless Steel Braided Hoses for Defender 110 to 99 TF602L New Part#TF602L & TF602 I have 3 of each side
$25 each - New Proline Lamp Assembly Front Directional LED Clear Model #: LED6489, LED6590 & LED6085
FITS: Series IIA-III (Can be fitted to earlier Land Rover models that have been converted to negative ground). Defender all models except NAS(North American Specification) 90 models 1995 -1997 (To fit to NAS 95-97 requires changing head lamp bezels to normal ROW bezels).
$50 - New Defender 90 & 110 Horn Turn Signal Indicator Switch STC439 Fits 91-9
$90 - New Discovery & Defender TD5 Wading Kit
$250 - Used Range Rover Classic PRC9949 One Touch Window Lift ECU
$120 - New 2-Inch, Class 3, Permanent Bolt-On Version, For Land Rover LR3, LR4 And Range Rover Sport from Atlantic British Standard 2-inch Receiver Class III - Rated for 5,000 lbs. Tow Weight & 500 lbs. Tongue Weight All-Steel, Heavy Duty Welded Construction Durable, Black Powder Coat Finish Easy Bolt-On Installation to Vehicle's Existing Mounting Holes in Chassis Mounting Hardware, Thread Locker Fluid & Installation Instructions Included
$75 - Used Range Rover Classic One Touch Window Lift Control Unit ECU PRC6859
$100 - Used Range Rover Classic Seat Switch Control PRC8095 With Cover And Buttons
$140 - New Range Rover P38 & Discovery II - 2 Secondary Air Pump Injection OEM Pierburg WIB100030 - Fits: Discovery Series II | '99 - '02 Range Rover 4.0 (P38) | '99 - '02 Range Rover 4.6 (P38) | '99 - ’02
I'm located in Cambridge MD for pickup. Willing to ship at buyers expense. I have a lot more that I haven't gotten around to listing, so if you're looking for something, please let me know.
