FS: 2006 Land Rover Range Rover Sport HSE, lifted
  • 2006 Land Rover Range Rover Sport - FS:  2006 Land Rover Range Rover Sport HSE, lifted - Used - VIN SALSF254X6A916226 - 174,500 Miles - 8 cyl - 4WD - Automatic - SUV - Black - Austin, TX 78723, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $8,000
    • OBO
  • Location Austin, TX, 78723, USA
  • Condition Used
  • VIN SALSF254X6A916226
  • Mileage 174,500
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type SUV
  • Exterior Color Black
~174000 miles.  2 owner (bought from a family friend).  Rust-free, Texas car.
4.4L AJ V8 (leaks ZERO fluids, no check engine light)
Recently rebuilt ZF 6 speed automatic transmission
Loaded model with black leather, navigation, sunroof, Harmon Kardon sound system, homelink, HID lights, bluetooth audio adapter, heated front and rear seats, memory drivers seat, heated windshield
Within the last ~15k miles the following has been done:
  • Lucky8 HD air compressor
  • Lucky8 front lower control arms
  • replaced all air struts (Dunlop and Arnott)
  • 2.5” Proud Rhino lift rods
  • Atlantic British front brake pads/rotors
  • new transfer case fluid, front and rear differential fluid, power steering fluid, brake fluid, fresh synthetic oil change, new front and rear sway bar bushings/end links, high flow air filter, cleaned MAF sensor and throttle body, new windshield washer pump, parking sensors, 4 wheel alignment, PCV valve, sunroof drain tubes, wiper blades, flushed heater core, new coolant tank, brake light safety switch
  • 32” Atturo Trailblade XT tires on LR3 18” wheels (matching size spare)
  • Atlantic British trailer wiring
  • Resonator deleted (sounds nice and throaty)
Before I bought it, the previous owner replaced:
  • water pump, serpentine belt, thermostat, valve cover gaskets, brake master cylinder, spark plugs, rear control arms, rear valve block
Known issues:
  • scratches/dings/clear coat issues. car was repainted black at some point.  Paint photographs better than it looks!
  • cracked dashboard (common, dash cover included)
  • sagging headliner in the back
  • small tears on some seats
  • drivers side heater doesn’t work (A/C is frigid cold though).  Will include blend motor to fix the issue
  • General squeaks, clunks and rattles
Including with sale:
  • Extra blower motor
  • New LR thermostat
  • Extra air compressor (for parts)
  • Extra front valve block
  • iCarsoft LRII diagnostic computer
Asking $8000 - blue Texas title in hand.  Additional $300 for factory tow hitch
Not interested in trades, not in a rush to sell.
Old Sep 24, 2022 | 11:01 PM
gb_junkie's Avatar
bump with a price drop
