H&R 30mm Trak+ DRM Spacers for Land Rover Discovery Range Rover Sport - Black
Wheels and Tires/Axles
  • Wheels and Tires/Axles - H&R 30mm Trak+ DRM Spacers for Land Rover Discovery Range Rover Sport - Black - New - 2014 to 2019 Land Rover Range Rover Sport - 2013 to 2019 Land Rover Range Rover - 2018 to 2019 Land Rover Discovery - Poway, CA 92064, United States
    Expired
    Expired
    Expired
    Expired
3rd Gear
    $189
  • Location Poway, CA, 92064, USA
  • Condition New
  • Compatibility
Make Model Year
Land Rover Range Rover Sport 2014 - 2019
Land Rover Range Rover 2013 - 2019
Land Rover Discovery 2018 - 2019
“New - Installed on the vehicle for fitment purposes only.”Information:
H&R Trak+ 30mm DRM Wheel Adaptor Bolt 5/120 Center Bore 72.5 Stud Thread 14x1.5 (Black) 60757260SW
Bolt Pattern: 5/120
Bolt/Stud: Stud
Guaranteed Fitments:
2013-2019 Land Rover Range Rover
2014-2019 Land Rover Range Rover Sport
2018-2019 Land Rover Discovery
Features:
Lightweight
Hard Anodized for durability and corrosion protection
Superior strength proprietary aluminum/magnesium alloy
Hubcentric for perfect fit and precise wheel alignment
100% Made in Germany
Improve wheel and tire spacing in fender
Better handling
Increased safety
Fix brake caliper clearance issues
Add inner fender and suspension clearance
 H&R TRAK+® Wheel Spacers move your wheels and tires outwards so they are more flush with the fender-instantly giving your vehicle the perfect stance! High end sports car manufacturers use every millimeter of fender space available in their design for the best looks and highest performance and so should you. With TRAK+® you can fill the gap in your fenders and GO WIDE! TRAK+® Wheel Spacers feature a ‘perfect fit’ hubcentric design that makes the spacer function as a precise extension of the axle hub, thereby guaranteeing precision wheel fitment. TRAK+® are designed, engineered, and manufactured by H&R Special Springs-100% Made in Germany. Constructed from a proprietary aluminum/magnesium alloy created specifically for the H&R wheel spacer program, TRAK+® Wheel Spacers are extraordinarily strong and lightweight. Additionally, TRAK+® feature a hard anodized coating for surface durability.
H&R® is an industry leader in high performance suspension components for a wide range of applications, including cars, trucks and SUVs. The company offers a diverse line of products divided into several categories including coilovers, sway bars, springs, cup kits, electronic lowering systems and wheel spacers along with camber adjustment bolts and lightweight race springs. Every product provides an unparalleled level of quality, reliability and performance to enhance handling potential, steering control and ride comfort of your vehicle.
