Johnson 1-1/2" Lift Rods for New Defender (L663)
For SaleMiscellaneous
For 2020-2025 New Defender L663. Creates 1.5" lift for Defenders with air-suspension. I removed them from my Defender because I purchased the Gap IIDTool G4. They are used but in perfect condition.
It is an easy 30 min. DIY job.
Price is USD + shipping
Manufacturers Description:
Johnson Rods are a premium lift rod made from 304 stainless steel and military grade rubber attachment points. They are stronger than the original OEM part. Our height sensor rods are built for durability in the most demanding conditions and can operate effectively in extreme desert temperatures and freezing cold conditions. Johnson Rods are designed in a fixed length with wider rubber attachments like the original part to prevent movement and problems associated with other adjustable rods and cheap copies . Johnson Rods are used by more Land Rover dealers and shops worldwide to provide an effective way to raise your Land Rover using the existing air suspension while maintaining the use of the terrain response system.
