L405/L494/L462 Custom Front Control Arm Setup
Steering/Suspension
  • Steering/Suspension - L405/L494/L462 Custom Front Control Arm Setup - Used - 2013 to 2023 Land Rover All Models - Cliffside Park, NJ 07010, United States
    Expired
    Expired
    Expired
    $300
    • OBO
  • Location Cliffside Park, NJ, 07010, USA
  • Condition Used
  • Compatibility
Make Model Year
Land Rover Any Model 2013 - 2023
Hey everyone. What I have here is a pretty cool custom setup for anyone who wants the front end a little more precise on their Range Rover, Range Rover Sport or Discovery (L405, L494, L462). So about the setup:
OEM Lemfoerder Control Arms
Polybush polyurethane bushing kit
Custom grease fitting tapped and ready to use with any grease gun
The arm started off as OEM arms which I removed the factory bushings from and installed the Polybush bushings. The difference in steering feel is DRASTIC. It feels like a totally different truck. Since poly bushings need to be regreased periodically and the only way to do that would be to take the arm out every time, I decided to put some grease fittings in the arms. This allows you to access the fittings and add new grease by just going right under the truck with a grease gun. SUPER EASY.
The setup will come with the bushings pressed into the arms and filled with brand new grease; I took them apart to show what is all included. The ball joints are in a great shape with just about 8k miles on them. I will also include the castle nuts for the ball joint end which can be reused,
Brand new this setup was $500 for the arms, $300 for the bushings to give you an idea of what it cost new.
Thanks for looking and give me a shout with any questions! Below is a link to the ebay ad as well.
L405 L494 L462 Land Rover Range Rover Control Arm bushings CUSTOM | eBay
