LT230 Output Shaft Flange Kit ROV-STC4379
Drivetrain
  • Drivetrain - LT230 Output Shaft Flange Kit ROV-STC4379 - New - 1994 to 2004 Land Rover Discovery - Charlottesville, VA 22902, United States
    Expired
    $90
    • OBO
  • Location Charlottesville, VA, 22902, USA
  • Condition New
  • Compatibility
Make Model Year
Land Rover Discovery 1994 - 2004
Didn't end up needing this kit and returning it is too complicated so putting up for sale here. These were out of stock everywhere and took forever to fulfill so hoping to help someone out. Item is still wrapped in the original packaging so I've attached the photos from the original ebay listing. I can open it up and add a photo of the actual parts if you'd like.
To help orient you, your front drive shaft connects to this and it sits in the front opening of your transfer case that's closer to the passenger side of the car. You'll likely need to replace this if you have a leak from the seal (#3) inside the case.
According to Rover Parts it will fit the following models
  • Discovery I | 94 - 99
  • Discovery Series II | 99 - 04 | DOES NOT INCLUDE BEARING
  • Range Rover Classic | 87 - 88 | 87-88 only
  • Defender 90 | 94 - 97
  • Defender 110 | 93
Contents: Front Output Shaft (includes flange, washer, felt washer, nut, oil shield, oil seal, bolts to output shaft & circlip. Numbers 7,8, 2, 4, and 3. It does not include 10 or 11.
