"Mitch Hitch" High Rise Tow Hitch
Miscellaneous
  • Miscellaneous - "Mitch Hitch" High Rise Tow Hitch - Used - 2006 to 2013 Land Rover Range Rover Sport - 2005 to 2016 Land Rover Discovery - Grants Pass, OR 97527, United States
    Sold
    Sold
    Sold
    Sold
    Sold
    $500
  • Location Grants Pass, OR, 97527, USA
  • Condition Used
  • Compatibility
Make Model Year
Land Rover Range Rover Sport 2006 - 2013
Land Rover Discovery 2005 - 2016
Used for just a few times. Allowed us to buy a trailer with a heavier tongue weight, and not use the “plow” OEM hitch adapter. It's a great product, but it's expensive to ship new from Australia. I'm selling my RR Sport so I don't need it anymore. I think I'm correct on the applicable model years but you should check for yourself. The following is from the Mitchell Bros website:
New sells for $647 US plus shipping. Willing to ship at buyer’s expense. 16 lbs. Designed and developed in 2007 by Aaron and Ben Mitchell the Mitch Hitch is the simplest way to solve the issue of the standard "plough" which has known drawbacks. There are literally thousands of Rovers out there sporting the Mitch Hitch, tried and tested for many years, so you know you can trust the Mitch Hitch. Even the Bush Tucker man grabbed one for his Disco.
Suits Land Rover Discovery 3 and 4 but also Range Rover Sport. Note: This does NOT suit new Discovery Sport models The standard Land Rover hitch issues below; Difficult to remove, especially if the locking mechanism seizes or fills up with mud or foreign matter. You're unable to remove the spare wheel with the standard Land Rover tow attachment fitted (Discovery 3 and RRS Only), can you imagine what it's like to remove the tow attachment if you've got a 3500kg van on the back and you're not on flat ground? Trailer/Caravan may not tow level with the vehicle without the use of additional equipment which adds cost and weight and complications to the whole assembly. Hangs too low, especially when off road. Has been known to fail, we have photographic evidence to show where the standard hitches have failed, probably subjected to excessive or repeated impacts. Not adequately rated for offroad. We knew about these issues when we set out to design a solution for the "Plough". The Mitch Hitch cures these issues. The standard cover plate can be trimmed to be reused for access to trailer plugs
Rated to tow 3500kg. 350kg Towball download. No locking mechanisms. Huge increase in departure angle. Simple and elegant design. Weighs only 8kg. Can remove spare tyre when the hitch is fitted. Engineer Certified to Australian Standards. Our hitch also; Raises the height by approx 200mm from standard for discovery 3. 150mm for Discovery 4 and Ranger Rover Sport. Puts the pin centre at approx 500mm from the ground (level surface).
Old May 4, 2021 | 02:37 PM
AndGorew's Avatar
4wd High
DM sent
Old May 5, 2021 | 12:30 PM
Rogue6's Avatar
Item sold
