Well Maintained 2014 LR4 HSE - 92,400 Miles
For Sale2014 Land Rover LR4
Selling my 2014 LR4 HSE with just over 92,000 miles (will go up slightly as I drive it occasionally). well-maintained SUV, Clean inside and out with service history
Recent Maintenance:
• Coolant crossover pipes replaced
• Thermostat housing replaced
• Fuel flange recall completed
• Vacuum pump and purge valve replaced
• Transmission & differential fluids flushed around 70–80K miles
• Front lower control arm bushings replaced
• gear shift module replaced
• About 15K miles on the current tires
• Fresh oil change tire rotation and alignment June 2025
• no rips or major wear on leather seats
• air suspension/struts will probably need to be serviced in the next 5k-10k miles - sags in colder weather but compressor is working fine (no warning lights)
• eco light on dash - auxiliary battery is dead and has not been replaced
